5400 vs 7200 rpm for streaming video.
Discussion in 'SSDs & Data Storage' started by Zefram0911, Oct 2, 2018.
  1. Zefram0911
    Zefram0911 [H]ard|Gawd
    1,150
    Apr 19, 2002
    Been a long time since I've bought a regular hard drive, but my 2TB drive is starting to click and I think is dying.
    Does rotational speed matter much if I'm using the drive as a media drive to watch 1080p videos?
    Thanks in advance for the thoughts.
  2. drescherjm
    drescherjm [H]ardForum Junkie
    14,167
    Nov 19, 2008
    No. You will not have an issue unless you are recording multiple streams at while trying to watch a stream or two.
  3. IceDigger
    IceDigger [H]ardForum Junkie
    10,426
    Feb 22, 2001
    It wont matter at all.
    If it is clicking though backup and replace ASAP!
    Sulphademus and Nightfire like this.
  4. pendragon1
    pendragon1 [H]ardForum Junkie
    11,156
    Oct 7, 2000
    what they ^ said. clone it before you lose your pron!
  5. Zefram0911
    1,150
    Apr 19, 2002
    Thanks guys. yeah, that's exactly why I was asking. Looking to buy a new drive and wondered if the speeds actually mattered, especially if I was using it to stream videos to another pc. It's a Western Digital drive that lasted me 6 years. seems like a reasonable amount of time to die.
    pendragon1 likes this.
  6. Luke M
    Luke M Limp Gawd
    338
    Apr 20, 2016
    I prefer 5400 for lower power and noise. The performance difference is irrelevant in the age of SSDs.
    craigdt, PliotronX and Susquehannock like this.
  7. Nightfire
    Nightfire [H]ard|Gawd
    1,339
    Sep 7, 2017
    5400 rpm ssd?
    DrLobotomy likes this.
  8. drescherjm
    14,167
    Nov 19, 2008
    I think that means if you want performance get a SSD instead.
  9. Nightfire
    1,339
    Sep 7, 2017
    Why? For storing and streaming videos, HDD spinners work perfectly fine. Movies take up a huge amount of space and who wants to buy a 2, 3, 4 GB ssd?
    I would like to have pictures in an ssd since the slower access time of HDDs can slow things down when looking through many very high definition pictures quickly.
    Back on topic. My internal 5400 rpm is tread fully slow and it was from a dead laptop. In fact, read/write access to my external 7200 rpm mycloud is faster. Get a 7200 rpm if you have the room.
  10. drescherjm
    14,167
    Nov 19, 2008
    The point was if you need speed the 7200 vs 5400 is irrelevant when we have SSDs. With that said I don't 100% support that argument. At work all of the hard drives I purchase are 7200 RPM. Although the bulk of these go into raid servers where I absolutely won't use a 5400 RPM drive unless it is for a backup only role.
    At home I do purchase 5400 RPM drives for my linux based PVR (8TB WDC externals to be exact). I am not using raid and the 5400 vs 7200 is not at all needed for even multiple simultaneous recordings and watching of HD video.
  11. coynatha
    coynatha Limp Gawd
    203
    Jun 9, 2004
    I couldn't stream 4K movies thru my Oppo 203 without them freezing every 30 seconds or so, without first moving the video file from the spinner(s) to the main OS SSD drive. 1080P worked fine.
  12. kdh
    kdh Gawd
    687
    Mar 16, 2005
    if you are doing 1 or 2 streams, like kids watching upstairs, and you are watching down stairs, a 5400 drive should be fine. If you are hosting multiple streams, a 7200 would be best. Could up the crazy, and raid a few 5400s together. Long sequential reads (watching movies) is not hard to do. Not sure if they are still around, but a hybrid sshd could also be an option. I have 1 in my "media" machine, and it holds up well recording at 24bit 96k audio, and playing it back.
  13. Nightfire
    1,339
    Sep 7, 2017
    I still don't get this argument. Thay is like saying the speed of a truck is irrelevant because we have sports cars. Some people still want fast trucks!
    Resolution is not really relevant, but bit rate is. The crappy "1080p" movies that my wife downloads are only 1000 kb/s. Most look pretty bad. When I rip standard def DVDs, I set it to 2000 kb/s. When I start ripping BLU-rays, they will most likely be around 5000 kb/s so they can fit on a DVD-9 if need be later. From what I gather, picture quality should be very close to BLUray. Still, 100 movies will use up a 1 TB hdd. Not many will be storing 4k movies for a while. That is part of the reason I got a One X!
  14. Arcygenical
    Arcygenical Will Watercool for Crack
    24,663
    Jun 10, 2005
    Laptop drives are pretty much always horrifically slow.
    pendragon1 and Nightfire like this.
