blackbeaSSt
- Oct 22, 2012
finally bit the bullet and upgraded to a sb6121 docsis 3.0 modem and a netgear wndr3400. while i was at it i put in a tp-link wn861n wireless card in my old thinkpad t42
but, i can't seem to get it working like i would have imagined it would.
installation went smooth (although i wasn't too sure about the black and white antennas and where they should go) with the tp drivers and wireless utility.
but when i opened the installed tp utility, i can't figure out how to connect to my network. it sees it in the utility but i don't see a "connect button"? also it seems to disable the windows wireless because i can't even find my network that way.
so i uninstalled just the utility and kept the driver. windows then picks up the network like normal and connects, but only at 54mbps.
what am i missing? why is the windows wireless showing 54mbps and why can't i connect using the tp utility?
