53C Load Temps
sanitarium16
Got my E6850 overclocked to 3.6Ghz. Load temp running prime 95 is 50-53C. According to the books im safe but do you think this is a little too warm?
Dude, that is FINE, even GOOD, for that speed.
Enjoy it. Stop worrying about temps. You are golden.
Those temps are very low for a Conroe at 3.6GHz. If they're being read correctly, you're doing very well.
While true, without knowing the ambient temps, everything is in the air...literally ;)
OP, provide ambient temps if possible, that gives the TRUE measure of whether or not your temp reporting software is in the ballpark.
depends. is it small fft's, or blend? ;)
i get similar temps on blend ;)
thats at 3.5 though :D
