Jun 20, 2004 #1 M mojoXP Limp Gawd Joined Mar 16, 2002 Messages 277 How well would a 2.8Ghz Northwoods chip (533mhz) bus goto a 800mhz Bus? I have DDR400 that wont OC for shit, or should i just get a 400mhz 2.8 and run Async?
Jun 20, 2004 #2 M mojoXP Limp Gawd Joined Mar 16, 2002 Messages 277 I should say steping up to 800mhz FSB... cause I know 4.2ghz P4 isnt happening under air... Anyone know the hit for async bus on a P4 system? How bad is it?
Jun 20, 2004 #3 merlin704 The Great Procrastinator 2FA Joined Oct 4, 2001 Messages 14,543 Grab a 2.8C. With any luck, you can get the CPU to hit 3.5Ghz with a 5:4 CPU/FSB Ratio, keeping the RAM at 200Mhz and the FSB at 250Mhz.
Jun 21, 2004 #4 S Stugots Supreme [H]ardness Joined Feb 25, 2004 Messages 7,301 not going to happen on air, and probobly difficult with phase change also. get a 2.8c or a 3.0c and run 1:1
