Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Newegg has both of them for under $200, but the 530J is cheaper than the regular 530. Which one is better? 530 530J
EDIT: I see the 530J has the XD bit thingy. That's the built-in virus protection, right? Is that something I want or something that will only get in the way?
you will not notice execute disable, which contrary to AMDs propaganda department is not virus protection, but prevents a certain kind of buffer overflow. XD will not get in the way, but in certain cases will be a good thing for you.
if A J was the same price or cheaper, it would definitly be my first choice.
If you really wanted to OC, I'd look at the 540J which also has a feature akin to SpeedStep.
