520 HX or 620 HX
acameron_56
Hey, I need a new psu, and I want it to be modular. I hear that the corsair psu's are great, so I plan to get one, but I am not sure which supply to get, especially since the 520 is $70 after rebate at the moment. My rig is as follows:
DFI LP DK P45 T2RS
Q6600 - 3.5 @1.37V with zalman 9700 heatsink
4 sticks of 2x1 Mushkin HP6400, 4-5-4-11 - overclocked to 900 mhz @ 2.0V
8800 GTS 640 mb oced to 620 core, 1035 mem
Belkin F5D7000 wireless pci card
X-fi Extreme Gamer
Scythe Fan controller
1 Cd/Dvd drive
1 DVD burner
1 multicard reader
4 120mm ultra kaze 3000 rpm fans (usually set to run @ 2000 rpm)
2 120mm S-flex @ 1200 rpm
1 120mm S-flex @ 800 rpm
1 led 120mm fan @ 1000 rpm
1 40mm fan @ 3000 rpm
4 cold cathode lights and 3 led lasers
My forseeable upgrades are a tv tuner and potentially a new video card (I was thinking maybe a GX2). I am not completely confident on psu calculators, so I would much rather differ to someones personal opinions. Thanks!
ya that was my my thought, but if I will have a lot of headroom with a 520 I'd rather save the $80 now and upgrade to somthing like the 1000HX later on. Thanks for the quick response btw :).
Yep, its customer appreciation week at ncix :). Thanks for the link...very helpful, as are all anand posts :). I think I'll probly just go with the 520. There are only 11 left so I need to make the decision quickly.
Thats what I figured, but then again I figured that with mushkin too. Anyways thanks for the quick responses, I ended up buying the 520 HX because I am a sucker for deals :)
I think you'll be really happy. Mine powers an e8400, 2x HDD, 9800gtx and the fan runs so slowly I can watch the label on the fan as it spins :) Not to mention it is the quietest noise-producing part in my computer.
Ya, ncix is weird that way. The only way you get the sale price is if you select the product through the sales page. Oh well, with deals like this who am I to complain :).
I would recommend the 620HX in case you want to upgrade your system in the future.
I just installed my 520HX. Its silent! I got $20 off by purchasing this as a combo with 4GB of Corsair DHX RAM. Bringing it down to $69 AR.
get a 520 cuz when u upgrade u'll prob get the new nahelm
