Does anybody know how i can format a drive from 512 to 520 block size?
Found some guides when googeling but non of them seems to really work and some of them is verry "tricky"
To do the actual change, you can use santools. Depending on the particular drive/HBA you use to try the reblock/reformat the drive may or may not cooperate. With all that said, if you are trying to shoehorn non-manufacturer drives into a manufacturer-locked array such as a Clariion or other storage product YMMV.
