512mb Kingston HyperX PC4000
Cool, I got my kingston hyperx pc4000 a few weeks ago from best buy. Good ram.
Originally posted by Stanley Pain
I guess you haven't seen an AMD rig running 250+ Mhz?
Memory bandwidth really opens up at 220+. Not to mention your FSB bandwidth.
Cheers,
Mr. Pain
Most AMD systems are lucky to get 220Mhz on normal cooling. Maybe with extreme cooling quite a few get 250Mhz.
And its not the memory bandwidth thats increasing the performance, its the raise in the FSB speed.
The processor can't make use of that much bandwidth. Games require very little bandwidth past a certain point of around 3.2GB/s.
Loose timings for more bandwidth is just crippling performance especially for gaming. Heavy applications that can benefit from more bandwidth can use more but it still doesn't help out much.
The FX-51 and A64 3400+ are pretty well tied in performance because their the same speed with the same cache size even though the FX-51 is running with almost triple the bandwidth. Your not even getting double the bandwidth by running 250MHz instead of the normal 200Mhz most people overclock to on Athlon XP systems.
So its the increase in clock speed and FSB that will net more performance instead of the bandwidth from the memory.
Being able to set your timings at 2-2-2-5 is all that matters in getting the top gaming rig. Its why the A64 is better then the Intel processor at gaming. An on-die memory controller really cuts latency.
going to slowly start increasing my 2500+ and see how well it does. RIght now got it at 3200+ at 200fsb and full load temps are around 35c. Hopfully will get around 210/215 this week and see how it goes from there.
These memory modules don't clock to lower latencies at 400 MHz do they? for instance if I only ran them at 400 MHz would they do 2-5-2-2 or anything better than what they are rated for at 500 MHz?
I've got mine at 400mhz currently using 2- 3 - 3 -6, havent tried to go lower but I will if you want me to try it. Picked up two sticks sunday of PC4000 from BestBuy cause it was too good of a deal to pass up :)
Being to run the FSB/Memory at 1:1 and still getting 220+Mhz on an AMD system is what you want. Hence why DDR500 is the way to go.
Without any extra cooling on my NF7-s 220Mhz FSB/MEM is no problem for me (on PC3200 Mem). I'm quite sure with some cooling on the MCP chip as well as better memory I'd be able to hit the 250 mark no problem.
As far as timings go, they aren't THE be all end all thing in performance.
at DDR400, 2-2-2-11 timings (on a NF2 board) vs 2.5-4-4-11 timings make very little difference in games/memory benchmarks.
However running at DDR440 make a bigger impact on performance (as does getting into anything DDR440+).
Cheers,
Mr. Pain
-- btw, the latency on A64 rigs aren't that great because of the need for registered memory. The difference here being that the actual latancy of the controller + it's bandwidth available are what make it such a wicked performer (on chip controller and all).
Timings are more important then bandwidth. Games first of all cannot benefit from more bandwidth because they are only able to use a certain amount. If more bandwidth = more perforance then the FX-51 with triple the bandwidth would be alot better then the single channel A64's and its not at all. It performs exactly the same as the A64 3400+ in gaming benchmarks and applications that cannot feed off raw bandwidth without taking timings into account.
MaximumPC just did a full article on RAM this month and just changing the timings from 2.5-3-3-6 to 2-2-2-5 improved performance by more then 3% in just SiSoft left alone gaming performance thats all about timings.
The memory at DDR440 isn't whats increaseing the performance. Its the increase in system clock speed and FSB speed. Instead of buying PC4000 with shitty timings buy PC3500 with 2-2-2-5 or 2-3-2-5 timings and overclock to 220Mhz 1:1.
What are you trying to say? The A64's dont use registered RAM, only the FX-51. And registered RAM increased latency time. The on-die controller decreases latency and it can run at the same speed as the processor which is a better option then having it in the Northbridge but its bandwidth has nothing to do with it. The A64 has 3.2GB/s of bandwidth just like the Athlon XP. The FX-51 with its dual channel controller puts out over 9GB/s of bandwidth.
http://www.pcstats.com/articleview.cfm?articleid=873&page=5
If the front side bus is kept at the same speed there is at least a 3% or more performance gain from tighter timings.
The performance difference between the Pentium 4 and A64 of same speeds in game benchmarks is alot of the time less then 3% so yes timings are important and continual increases in bandwidth doesn't net more performance.
It all depends on how much the individual processor can benefit from added bandwidth. 3.2GB/s is more then enough for Athlon XP's and A64's and Intel processors have dual channel which makes 3.2GB/s into 6.4GB/s so theres no reason to buy PC4000. PC3500 will take most all Athlon XP's using conventional cooling to their limit and still keep tight timings.
I still cant believe how much more expensive these sticks are going for on Newegg.
thats just crazy....
Went back for a second pair.. They don't work on my IC7 at 250 :(
Guess I am gonna drive back down there and switch them out.
You you probably got Samsung like me, says SAM on the dimm package. Hynix is what we want. I need to go back and see if they have any.
The Abit IC7 series is picky about what RAM chips will work on it. The MAX3 doesn't like CH-5 chips very well.
If your wanting the best performance i would get PC3200 or PC3500 from Mushkin and just set your divider to 5:4 or 3:2 depending on how high your planning to overclock. Your performance will be anywhere from 3-5% better then what you can get with the PC4000 and you'll be able to overclock higher with the dividers then you would in 1:1 with PC4000.
Ive got my Abit nf7s 2.0, XP 3200+, and 512mb KHX pc3200 @ 420 fsb right now. My ram is what is holding me back Im geussing. I put up any timings and it craps out... I can get into Windows at 430-440 but then I get horrible memory errors. Memtest isnt stable above 420+ at all. Im going to use my friends Bestbuy discount (he works there) and get this ram for even cheaper! WOOHOO!
Just buy 1GB of Mushkin PC3500 lvl 1 for $210 at newegg. Its not much more then what you would pay for a 1GB of this stuff and you'll get better performance especially for gaming.
Raising your clock speed and FSB alone wont give you better performance if your timings are shot. At least not in anything that takes timings into account. Most people never get over 220MHz with an Athlon XP system anyways so you've about reached your limit there at 210Mhz system clock.
I would say your Processor has just as good of chance of being at its limit as your RAM. A 3200+ isn't going to overclock any better then a 2500+. And unless you've got one with the multi unlocked then your stuck with an 11x multi.
Now my other set is acting flaky. I tried to exchange them but the BestBuy in Savannah is all out. Bought a 15GB iPod instead.
