- Mar 19, 2003
Of course with MFG it will be faster... but not exactly the same experience depending on the game etc.
Is that MFG 3x/4x in Cyberpunk 2077 already?Of course with MFG it will be faster... but not exactly the same experience depending on the game etc.
Thanks for helps. Hope i will get card tommorowYes, 3x/4x MFG is available in Cyberpunk if you have a 50 series card. And latency is fine at 4K with a 5090 with a very playable game.
We will know in less than a hour if 4090 with FG 2x pumps more FPS /2 or less than 5080 with MFG xN pumps FPS /NHi. Here 5080 is much slower than 4090, on 1440P. But with MFG 5080 will be faster?View attachment 707106
Uh thank you so much for large explanation.We will know in less than a hour if 4090 with FG 2x pumps more FPS /2 or less than 5080 with MFG xN pumps FPS /N
5090 is more efficient in MFG than 4090 with FG or in other words have better scalability of frame generation algorithms. Most likely because implementation for Blackwell uses FP4 model versus FP8 on Ada Lovelace.
If this is the reason and it seems likely 5080 should be more efficient for frame generation also.
Or in other words if someone likes* FG and has fast monitor then 5080 can be faster card.
Let's use napkins...
From Techpowerup review 5090 has 54 fps -> 105 fps in 2x mode so scaling is 94.4%. 4090 has 74fps -> 74fps so scaling is 72.1%
In this case expected numbers are:
4090: 152.4 fps -> 262 .3 fps
5080: 132.7 fps -> 258 fps
Still not faster than 4090 even in this case.
And keep in mind that 5090 has massive memory bandwidth advantage over 4090 while 5080 has actually slightly slower bandwidth (1.01 TB/s vs 896.0 GB/s). Also 8GB more VRAM is already needed in some of today's games with max settings to use FG.
But then again 4090 here is just 1.6% faster and limited to 2x frame gen while 5080 will do also 3x and 4x and you won't probably want to 4x frame rate from max settings anyways and rather use DLSS. Also 4090 are crazy expensive even for second hand cards with around year warranty which execution might be problematic so...
yeah No point in upgrading from 4080No point in upgrading from say 4080 or 4070 Ti Super. But worth it if you're using 3080.
Looks to be a good overclocker, almost 13% from Techpowerup review.
Yes once again upgrading in slot every generation is showing to be pretty pointless. Cheers to all the 3000 series holdouts! I'll buy a 4080 if someone wants to sell it for less than retail 3 years later... Hit me up!No point in upgrading from say 4080 or 4070 Ti Super. But worth it if you're using 3080.
They are bringin FG 4x to the 4000 series cards. So, dont need a 5000 series for the fake frames.Yes, 3x/4x MFG is available in Cyberpunk if you have a 50 series card. And latency is fine at 4K with a 5090 with a very playable game.
Really FG 4x on 4000 ?They are bringin FG 4x to the 4000 series cards. So, dont need a 5000 series for the fake frames.
Talk about a huge letdown. This is a 5070 card.
One Nvidia guy said it could now be technically possible* on all RTX card but we all knew it should be possible on at least Ada Lovelace. In fact the only reason FG was limited to 2x was for Jensen to be able to say 5070 had 4090 performance.They are bringin FG 4x to the 4000 series cards. So, dont need a 5000 series for the fake frames.
Looks like Debauer has massive pcie 5.0 issues with his 5080. So something to note for people wanting the FE card:
View: https://youtu.be/IvQwlN1sE0U
I don't know what games you play but I don't think the 3080 ti is faster than the 4080S in any games I saw that were reviewed.This is laughably bad. It trades blows with a 4080 Super, that's just plain shit!
I briefly upgraded from my 3080ti FE to Gigabyte 4080 Super OC and found it to be barely faster in the games I play, in same cases actually slower, and subquently returned it. If the 5080 is on a par with that then it's not even an upgrade for me!
Anyone with anything better than a 3080 should ignore the 5080, unless all you wanna do is play Cyberpunk 2077.
Yes, he wasn't able to run at 5.0 speeds (which the card is designed for) and was only able to be able switching to 4.0 in the bios. This was with a 5.0 motherboard.Its something with change pcie /speed in mboard bios.
Someone on reddit mentioned this. Nah i will watch soon. ThxYes, he wasn't able to run at 5.0 speeds (which the card is designed for) and was only able to be able switching to 4.0 in the bios. This was with a 5.0 motherboard.
Did you even watch the video? He explains it all.
MFG 2x is coming to the 4000 series last I checked. 3x-4x is not, unless you have a source for that.They are bringin FG 4x to the 4000 series cards. So, dont need a 5000 series for the fake frames.
Even at a CPU-limited resolution like 1920x1080 the 4080 SUPER is 25-30% faster.I don't know what games you play but I don't think the 3080 ti is faster than the 4080S in any games I saw that were reviewed.
Only thing 3080Ti has going for it is faster memory bandwidth but it still loses in all benchmarks.I don't know what games you play but I don't think the 3080 ti is faster than the 4080S in any games I saw that were reviewed.
3080 Ti has 12GB and not 24GBEven at a CPU-limited resolution like 1920x1080 the 4080 SUPER is 25-30% faster.
I could be wrong but doesn't the 4000 series already have FG 2x? Or it just FG 1x?MFG 2x is coming to the 4000 series last I checked. 3x-4x is not, unless you have a source for that.
The 3090 and 3080 Ti are both around the same level of performance.Only thing 3080Ti has going for it is faster memory bandwidth but it still loses in all benchmarks.
3090 I could agree upgrade would be kinda pointless and feel like side-grade but with 3080Ti.. come on!
It is more like performance wasn't improved enough versus price to bother - which is understandable.
...that said today with DLSS Transformer taking massive performance hit on 20 and 30 series compared to 40 and 50 series that these older cards don't look that hot.
No, I was just thinking about previous Ti cards and didn't confirm my memory. The 1080 Ti had 11GB vs. 12 GB on the Titan X and 8GB on the 1080, for example. I had forgotten that they didn't increase the memory on the 3080 Ti over the 3080 12GB.3080 Ti has 12GB and not 24GB
You were probably thinking about 3090 Ti
Could just be a confusion of terms again. That might be what they're calling the original "DLSS 3" frame generation now.I could be wrong but doesn't the 4000 series already have FG 2x? Or it just FG 1x?
Nah stay with 4080. Even there are no good games actually. Maybe CB 2077 or Doom Dark Ages in May or maybe Stalker 2.There's just no way I can justify on principal upgrading to the 5xxx series from my current 4080
My 4080 was a 50% upgrade from my 3080
And my 3080 was a 40% to 50% upgrade from my 2080.
But the 5080 being ONLY 10% to 15% than my 4080 is a joke.
And the 5090 costing $2,000.00+ and it's only a 25% to 30% "upgrade" over the 4090 is also a joke.
These are the worst gen to gen "improvements" in a super long time.
So people that already have $800 video cards can skip the new ones?! What a relief! I agree with your statement but we all know Nvidia has been stingy with the vram on sub $700 cards for a while now.if gpu Vram is sufficient.
Something like thatSo people that already have $800 video cards can skip the new ones?! What a relief! I agree with your statement but we all know Nvidia has been stingy with the vram on sub $700 cards for a while now.
This generation is more disappointing than the GTX 500 series.
