500K ppd for Top 20?!?
Delemon
According to this, it'll take half a million points per day to break into top 20!
Way awesome for those of you up there, and WTF for those of us trying to figure out how much its going to cost to break into that top tier!
Grats guys, fold [H]ard!
Even if you overclock that $3k server you still won't be [H]ard enough for the top 20. You almost need two :eek:
A good enough 4p will put you in the top 20. I'm getting ~700k out of one.
How to do you get 6900 series units? I thought everyone's 4ps were getting straight 8101 units like mine.
8101 is just under 500k on that machine right?
A bit over. The p6901 that I'm processing now is 534k ppd (4m58s tpf). p8101 should be similar ppd.
To get ~700K out of a 4P would be a higher end 4P IMO. 6176s or 6180s OCed 20% to 30%. A 4P with 6128s would be 'good enough' IMO.
My "temporary" 4P setup with 6128s will not come close to 500K PPD.
Only around 380K PPD on the best 690x WUs (about a 25:50 TPF I think).
This is with an OC of 247.
I believe you will need 48 cores running at least 2.2GHz based on my experience.
I don't think you can guarantee it with only 1 4p. If you get a string of 8101s or similarly low scoring WU, you'll be under 500K with anything but the fastest 4p with a strong OC.
My system is a higher end system. 4 x 6180SE with a 15% OC. However, the price was about the $3k figure that was quoted a few posts up.
with $3k .. can you have 2x 4p 6128? I guess you can .. and PPD will be higher . :D
I believe you are right I have 1 set of 74's that run at 2600 which will hit 700K on a occasional 6904 but there is no way it will do it on a daily basis
It's actually a little less than 500K, once the OCFThanks[H] thing is over #21 makes ~460k PPD.
And who would that slacker be at #21 (and 22 for that matter)??? They need to pick it up to keep the top 20 at 500K ppd.
(UTO and kendrak, I'm talking to you...)
it would be 431k to be in top 20 .. cuz I switched back to my team...:D
