5000+ MB and memory recommendations?
jmacken37
Looking to set up a budget gaming system that I'll overclock and use with RAID0. Any recommendations for:
1) MB
2) Memory
3) cooler
4) case
Thanks,
Jake
Biostar T570 SLI Mobo $80?, G.skill DDR2 memory $35 for 1gb, Rosewill Z3 cooler $30, Raidmax case with side window $30.
I got my 5000+ BE w/ 2GB XMS2 Corsair for $176 w/ $40 rebate. Although I went with the ASUS M2N-SLI Deluxe mobo and CM690 case ($29.99 AR w/ card reader).
Everything after rebates will be $296 but I already have an Arctic Freezer 64 cooler but bought a Tuniq Tower...
I've read that Biostar, you're unable to go above the 13x multiplier. Kind of defeats the purpose of an unlocked multiplier IMO...
Where are you located? If local, I can hook you up with a CM 330 Elite for cheap and my AC64 once my Tuniq comes in...
