500$ Processor, Mobo, Video Card, and Memory, what do you think
Vengance_01
Well I am thinking of dumping my laptop. I really don't use it for what I should, and I could build a desktop for 1/3 less and get better preformace. I already have everything eles, and I just need Processor, Mobo, Memory, and Video card. This is what I have come up with as being the best bang for my buck while having great preformace.
From newegg:
Motherboard: DFI nF4X Infinity Socket 754 NVIDIA nForce4-4X ATX AMD Motherboard - Retail-75$. Have memory voltage up to 3.2, high voltcore, and should scale pretty high on the HTT(Around 300 or so I am guessing)
Processor: AMD Mobile Athlon 64 3000+ (DTR) ClawHammer 800MHz FSB 1MB L2 Cache Socket 754 Processor - OEM. I know its not a ture Moblie, but good chances this thing will hit 3700 Speeds and higher(has 9 multi) and it having 1 meg L2 cache only helps. only 111$
Memory: Crucial PC3200 Ballistic 512MB x2 for 1GB These stick use micron chips and are capable of Low latceys@2/2/2/5 and keep 2.5/2/2/5 up to about DDR 500-550 with enought voltage which the DFI can provide. 60$ per stick, which is great for LL memory. Bit more than value ram, but worth it here.
Video Card: MSI RX800-TD128E Radeon X800 128MB 256-bit DDR 12 pipe PCI Express x16 Video Card - OEM all in likely hood this a ture X800Pro core sold with haft the memory to keep cost down. Core is clocked at 392, which I am willing to bet it can hit 450-475, and memory is DDR, but should O/C some what. at 112$, you really can't beat that. 12 piped card, and 256bit memory bus, this card should beat a 6600GT, which can be had for about the same amount.
Your probally wondering why I went Socket 754, when a 3000 Venice is around 140$ retail. Simple fact is I have had bad luck with the few I have played with. Plus I am looking to spend the very bare min and waiting for Dual cores and M2 to be in full swing. Later down the road I can always grab a Moblie Turion for extra clock speeds. DC is not worth much. This was 427$ and 469$ after tax and shipping. I will be comming up with a 939 setup and posting the two to compare. Please post comments and concerns. If you do have a setup please post, but it must be PCI-e and can not include ebay or forum buys. Only from stores, or online sites. Also mabey someone would like to chanlenge me to a buget build off, might be fun LMK.
This is me just thinking out loud, but please post comments.
Go 939. I understand that you haven't had the best of luck with the Venice cores, but facts are facts, and Venice cores will overclock better.
Pish-Paw.
OpterOWN.
