500 off HP over 1199
http://www.shopping.hp.com/webapp/s...&series_name=m9600t_series&afsrc=1&aoid=35252
configure it to 1199 then use coupon code DT5446 for 500 off bringing an i7 system down to 699.
Here's the exact configuration you'll need:
* – Genuine Windows Vista Home Premium with Service Pack 1 (64-bit)
* – Intel(R) Core(TM) i7-920 processor (2.66GHz, 1MB L2 + 8MB shared L3 cache with QPI Technology)
* – 3GB DDR3-1066MHz SDRAM [3 DIMMs]
* – 500GB 7200 rpm SATA 3Gb/s hard drive
* – 512MB ATI Radeon HD 4350 [DVI, HDMI, VGA adapter]
* – LightScribe 16X max. DVD+/-R/RW SuperMulti drive
* – Integrated 10/100/1000 (Gigabit) Ethernet, No wireless LAN
* – Integrated 7.1 channel sound with front audio ports
* – 15-in-1 memory card reader, 2 USB, 1394, audio
* – No TV Tuner w/remote control
* – No speakers
* – HP multimedia keyboard and HP premium laser mouse
* – Microsoft(R) Works 9.0
* – Norton Internet Security(TM) 2009 - 15 month
* – HP Home & Home Office Store in-box envelope
Comparison:
i7 920 = $280
Mobo = $170
Ram = $50
Case & PSU = $100
OS = $80
DVD Drive = $25
Total = $705
Tax was $41 or so on the HP, and you might not have any tax if you order the parts yourself, but overall the prices are pretty dang close. You can pretty much have the same exact thing already built for you for the same price. Not too shabby!
it does not have to be that exact config the coupon is 500 off anything 1199 or over. So you can make it a 9 gb system and lower the other components. Coupon is only good for 200 redemptions btw.
He also forgot to add the video card.
You forgot to add a hard drive to the DIY list ~ $55 to $65 for a 500gb or 640gb
Think you forgot a separate video card as well. (ninja edit ;) )
No, I didn't forget. When I added the video card the total was $819, (even with code - it replaced the $300 IR with the $500 - you don't get both) not $699. Try it yourself.
Yep, once the $500 coupon is applied, the $300 IR gets axed.
