$500 - Choose my machine
Nipsy
Okay, the last time I built a box, AGP was king, the AMD 2100 was the most tweakable, and NForce had no numbers tacked on the end. Power supplies were all the same form factor, and dual channel memory was the new hot ticket. I was able to run a stable 2800 out of my 2100, and it suited me just fine. I'm looking to build that sort of machine again.
I am not a gamer, I will use the machine primarily as a dev box, and a Photoshop batch processor. I would like to be able to batch process 1000's of images without a hiccup (auto-levels, resize, save PSD, output for web, resize, repeat, resize, repeat). The macro I wrote took a good 11 seconds per image on my last machine. I would love to trim that down a little.
Stability is more important than out-right speed. I would like to be able to run games on rare occasions, but since the eye can only see 30fps, I don't need to break that speed. Dual monitor support is key, as well as building towards a 2 year life cycle. I will be doing most of my work on my other machine, and want the ability to feed a machine a bunch of tasks, and trust that it will complete them without failing. I would like PCI-X/939/NForce4 since this is where processors will likely evolve, and even with a 2 year lifespan, I usually throw some upgrades at the machine after one year. That said, I am willing to look at other combos. Again, I am not playing anything more serious than Warcraft 3 so I don't need a nuclear powered nitorgen cooled video card.
Now, I need to replace my dead 2100 setup, and am looking to spend about $500. I bought the 2100 when the 2800 was out, as I could OC it to a 2800 and save a hundred bucks, so I'm looking for that 'sweet spot' processor again. I built this shopping cart, but it is a bit more than I wanted to spend:
80701-2 AMD Athlon 64 3200+ Processor Socket 939 Retail ***Free 2nd Day*** 1 $190.00
241158 MSI K8N Neo4 Platinum nForce4 Ultra Athlon 64 Skt939 DDR ATX Motherboard w/Audio, Gigabit LAN, RAID/Serial ATA Retail ***Free 2nd Day*** 1 $139.99
85018-10 Kingston KVR400D2N3K2/1G 1GB Kit DDR2-400 PC2-3200 Memory Retail ***Free 2nd Day*** 1 $159.00
324541 Asus EN6200TC GeForce 6200 PCI Express 64MB DDR Video Card w/TV-Out & DVI Retail ***Free 2nd Day*** 1 $68.00
270001 Antec TruePower 2.0 TP-II 550 550W Power Supply Retail ***Free 2nd Day*** 1 $119.99
Subtotal $676.98
I already run a RAID which covers my storage needs, and I have a big ass beige still does the job case, so I'm looking for ideas on how to improve the other variables (or better deals on the hardware I've chosen).
Please let me know what you would do on my budget...
DDR2 will not work with your system, you have to get DDR. (and it is cheaper)
A 3000+ on S939 should help in price a bit. (and should be similar results in OCing)
==>Lazn
Okay, if DDR 2 won't work, how bad is the Geil memory?
Or:
What memory should I buy if I'm looking to get a gig and dual channel it for about $150?
Taken directly out of another thread with a similar question:
MAValpha said:
I'd say that the Xpress200 IGP motherboard is your best friend, for $93. Its built-in graphics are on their way to being halfway decent, while still leaving you a PCI Express slot with which to upgrade later on.
Then get the retail s939 3000+, which comes with a good-enough HSF while still costing less than its OEM counterpart at NewEgg- $146.
512MB of RAM is enough for a budget comp today, so get 2x256MB of ValueRAM with a major name behind it for $48- the extra latency isn't an issue on such a limited budget, and it only costs you a few percent anyway. Wait, you're using a lower-speed CPU anyway- WHO CARES about a few percentage points? I trust Corsair, though there are mixed reactions to their Value Select series.
That'll leave you about $200 for a case, PSU, and drives. Figure around $100-120 for drives/storage depending on size and capabilities (CD-RW, DL DVD+/-RW, that sort of stuff), and you've still got about $80-100 for a case & PSU- you can find plenty in that range, just be careful to get a reliable Power Supply.
Try NEC's DL DVD+/-RW drive for $52, it's one of the best while still keeping a low price tag.
NewEgg also has your choice of 80GB, 7200rpm, 8MB cache hard drives in the $60-70 range, I'd go with the Seagate SATA drive for $60 after instant rebate.
Pick a case and PSU. Here's a suggestion for $70. It's an awesome, reliable case, and it comes with a 350W PSU- most likely Cooler Master's own RealPower. I have their 450W model, so I trust their manufacturing. Keep in mind that 350W won't let you upgrade to SLI or anything heavy-duty later on, but it'll do for a budget PC like this one.
You can trim a few bucks by recycling your old stuff and maybe getting a cheaper optical drive, and use the extra money to buy any cheap PCI video card (not PCIe) for your second display- ATI recommended to minimize driver conflicts. You could also get an X300SE or higher and use SurroundView for TRIPLE-display, but I think these are more expensive than, say, a Radeon 7000/VE PCI.
Go with a 3000 instead of 3200 (and possibly hold on for Venice any time now and not priced that much higher, with better memory controller for one thing). They overclock easy if you want to, and memory dividers aren't a bad thing on the A64.
You can get the DFI nF4 UT for about that price (think mine was $137), and they're currently the best for nF4 boards.
DDR2 = not something you want anyway, and not compatible. TwinMOS SP PC3200 (CH-5, great stuff) is on sale at Newegg for $55 per 512MB stick right now. Great price, great memory. Link in Hotdeals forum if you have trouble finding the right one.
Just get two identical 512MB sticks of any DDR PC3200 from a decent brand. (corsair, crucial, kingston, mushkin, geil etc.)
There is nothing special about Dual Channel Ram, they just stick two ordinary sticks into the same plastic package.
==>Lazn
What are memory dividers?
______________
I do not need an optical drive as I'll be recycling, nor do I need tri-view (however, it is nice to know about that card, as it may make it into my next home machine!).
I appreciate the deals on DDR 400...gald to know DDR2 is incorrect, save me some hassle there.
Appreciate the help so far...
Memory dividers...
In your computer there are a few different clock signals that drive everything. CPU and memory both go off of the FSB clock, which is typically at 200MHz these days.
CPU will use a "multiplier" to get to its clock speed. In the case of the AMD 3000+ Winchester, its multiplier is 9, giving it a stock clock rate of 1800 (1.8GHz).
The memory divider expresses its relation to the CPU and the FSB clock. A 1:1 memory divider is the default, so with a 200MHz FSB you would get the memory also at 200MHz, although with DDR memory sometimes they express it as 2x that number (so 400MHz, which is the default speed for PC3200 memory) because DDR SDRAM or Double Data Rate SDRAM runs at twice the command rate of the original SDRAM as DDR uses both the rising and falling edge of the clock signal, effectively sending double the data at the same clock speed.
So assuming you wanted to increase the CPU speed, you'd up the FSB, and the CPU speed would increase by that amount times the multiplier. However what if your memory can't run as fast as the new FSB would make it? Then what you do is use a different memory divider setting than the default 1:1, so that you can have the memory running at a lower speed, or still at the stock speed, while the CPU is running significantly faster.
Winnie 3000+ (and presumably Venice once it's out, again it'll be very soon now and it's probably a better choice) can be very easily overclocked to about the speed of a 3500+ with nothing more than stock cooling without altering the RAM speed more than a fraction, so you can have it going as fast as a CPU that costs twice as much...you see the lure of overclocking now, I hope? :D
shadowbreaker513 said:
Not to be offtopic but
is wrong. Most people can't tell above 72 or so but some people can notice the difference to almost 100.
True but I did not want to get into that either. Suffice to say, at ~24fps the brain starts getting tricked into seeing motion instead of a bunch of stills, but less than 30hz and you tend to get sick from the flickering. (this is why movies run at 24fps with each frame shown twice, so a refresh rate of 48hz)
As for what is actually detectable by the human system, Air Force tests suggest up to 300fps is detectable, but most people are happy with ~60fps.
http://www.100fps.com/how_many_frames_can_humans_see.htm
==>Lazn
Even if it was true you could only see 30 frames per second...would the computer be able to change them at exactly the right instants that you'd be looking?
You don't need the 3200+ if you are going to OC. Just get a 3000+, OC it to 3500+ speeds, and save yourself $40. Here's what I could get for the mobo, CPU, and memory
Power Supply:
380W Antec TruePower - $65
Motherboard:
MSI K8N Neo4-F - $90
Processor:
AMD Athlon64 3000+ - $146
Memory:
Corsair Value Select 1GB (512MBx2) - $88
Subtotal - $389
The memory is not cheap quality memory. It's very good and I've heard of people getting good overclocks on it. Now about the video card, you have 3 options:
High-End:
6600GT - $179
Medium-End:
6600 (non-GT) - $139
Low-End:
6200 (without TurboCache, 256MB on-board memory) - $110
All of these are good cards. The 6200 will play current games on Low, the 6600 will play on Low-Medium, and the 6600GT will play on Medium-High. Totals are (Shipping included, $15 estimate):
High-End: $583
Medium-End: $543
Low-End: $514
I suggest the High-End (who wouldn't).
Okay,
Before I go plonking down the cash, should the 380w PS above hande:
Mobo
Processor
4 HD
2 Optical
PCI Express Video
PCI Raid Card
Case fans
Also, assuming I need firewire and don't want to sacrifice a slot, I should get the Platinum Mobo?
Almost there...
As long as you are not using a GeForce6800 or higher, you should be fine. Just to be safe, though, see if your RAID controller lets you stagger your hard drives; offsetting their spin-ups reduces strain on your PSU.
Nipsy said:
Okay,
Mobo
Processor
4 HD
2 Optical
PCI X Video
PCI Raid Card
Case fans
Almost there...
Yes, those Antecs are good powersupplies. However if you plan to upgrade to a 6800GT or X800 video card in the future, you would have to replace that PS.
FYI: PCI-X is not PCI-Express, it is a older server 64bit PCI standard. PCI-Express is normally shortened to PCI-E to avoid confusion.
==>Lazn
Correct, although "PCIe" is the more official abbreviation. In fact, the PCI-SIG (www.pci-sig.org) uses PCIe itself.
Get 2 of these for RAM if you are planing on OCing your RAM and up the voltage to 3.2. It's the best value by far, just seach the forums about is and read this. But also remember that RAM on A64 does not improve performace by much at all. So if your not much interested in OC your RAM then just get the cheapeds 1 GB combo at the egg. There are many reviews that prove this. Also probably the best quality/performance/price Powers supplies are forton, I have one personally and it is amazing. I have built PC's for 2 friends using this PSU and they work flawlesslessly, a search through the power supply forums will give you a better idea. I would suggest either this or this. 400 watts should enough for you. But if you are OCing LOTS and want to be on the safe side.
Power Supply:
Motherboard:
Processor:
Memory:
Subtotal - $389
High-End:
6600GT - $179
Medium-End:
Low-End:
High-End: $583
Medium-End: $543
Low-End: $514
Go with a larger PSU for nF4 chipset Mobos even without SLI 480W+ is recommended (good quality) and if U are planing on OC do get the 3200+ That 10th multi might save your butt. 10*260 = 2600 while 9*270=2430 the choice is easy and its worth the 40 Bucks.
