$500 Build
vvk
Some gaming -- Starcraft 2, Portal 2, etc. Programming (mostly Java and C), web browsing.
$500 max with everything included. If a $550 setup somehow blows the $500 system out of the water, then I'd consider the extra $50, but preferably the lower the better.
3) Where do you live?
North Carolina, USA
CPU, GPU, motherboard, RAM, CPU cooler (if necessary)
Antec 900 case
WD Caviar Black 640GB HD
This PSU
All of these items about 2.5 years old.
6) Will you be overclocking?
No
22 inches
Within a month
Windows 7 Professional 64 bit
My 2.5 year old system recently broke down on me and I need to replace it as soon as possible. The PSU and HD are still good, so I will reuse those. My main goal here is to build a reliable, relatively speedy system that will last me through my last year in college. I might end up purchasing a brand new one after that, since (hopefully) I'll have a decent job and be making some money, so I'm willing to settle for cheaper components that will do the trick in the meantime. Please let me know what you recommend -- I've looked at some Core i5 systems that push $500 -- not sure if it's worth it over a cheaper Core i3 or AMD build.
Thanks!
vvk
I'll give it a whirl :D
$319 - 2500k + p67a-c43 mobo - http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.642513
$40.99 - CORSAIR XMS 4GB - http://www.newegg.com/Product/Product.aspx?Item=N82E16820233132
$99 (after rebate) - GTX 460 - http://www.newegg.com/Product/Product.aspx?Item=N82E16814162058
$459 after $50 rebate
The video card is overkill for the games you listed on a single monitor
Another option, amd side (Important: don't overclock with this motherboard)
$54 - a880g+ - http://www.newegg.com/Product/Product.aspx?Item=N82E16813138283&cm_re=a880g+-_-13-138-283-_-Product
$159 - amd 1055t six core- http://www.newegg.com/Product/Product.aspx?Item=N82E16819103851&cm_re=1055t-_-19-103-851-_-Product
$352.99 after $50 rebate
I've built both systems (with a slightly different mobo for the i5 and evga 460's), both are very fast, and I use both for dev work (Visual Studio, Eclipse, IDLE)
Honestly I can't really tell the diff between the two as both are very fast systems. The AMD system does use more power and the stock fan spins up to 6700 rpm under load, but for the price it's a darn nice setup.
