$500 budget gaming system - possible?
I would look at getting a 6800LE instead of the 6600GT, its clocked lower but you have a chance of opening the other 8 pipes and I beleive its 2 shaders. The 6800LE is 128/256 which the 6600GT is only 128/128. You also can oc to get some more speed outta it.
Total: 489.75
with Ram: 579.75
with DVD drive: 624.75
http://www.newegg.com/Product/Product.asp?Item=N82E16822144102 - HDD-51.75
http://www.newegg.com/Product/Product.asp?Item=N82E16813131541 - Asus-93.00
http://www.newegg.com/Product/Product.asp?Item=N82E16819103537 - 3000+ 146.00
http://www.newegg.com/Product/Product.asp?Item=N82E16814150068 - 6800-169
http://www.newegg.com/Product/Product.asp?Item=N82E16811156167 - case w/380-30.00
Now you have to decide whats the weakest link or do without until you get more cash.
Good Luck.
