50"
MirageMobile
How good would the display of a high-end computer be on a 50" plasma, perhaps for hooking up to play a DVD or run a game?
For desktop work, super crappy. Most plasmas use a horrendously low resolution. If you want to connect it to a PC, you have to go LCD. You sacrifice black levels for... usability.
Yeah - my 50'' plasma is 1366x768, which is pretty low for that kind of size. My 20'' desktop LCD is 1600x1200.
I sometimes run my comp on my 1080p 52" LCD TV and as long as you are not sitting right in front of it, it seems to be fine for both desktop work and gaming.
HD1080 is a whole 'nother ballpark compared to WXGA (1366x768). What looks good on HD1080 isn't going to look very good on WXGA.
If you are looking at a 50" Plasma or LCD, make 100% sure you know what the maximum resolution is. As was mentioned above if you are looking for a quality television, make sure it's 1080p so you get the best resolution possible. A 720p/1080i monitor is NOT going to look impressive--I have a Sony 50" TV and I only use it as a "spare monitor" for when I'm having an issue and I suspect the monitor is the culprit. It has no functional, practical use as the TV is about 8' away from the rest of my computer components, and I don't use a wireless mouse/keyboard/headset.
When I sold stuff at Circuit City (about 6 months ago, so not TOO long ago) I would gauge what size the person wanted, then recommend a size lower with a higher resolution. Demoing it was cake and more often than not someone would go with a slightly smaller (4" or 6" smaller) display in favor of a higher quality picture. Some people will immediately call it a scam since you can't use 1080p on a cable box or then-current satellite images (720p = HD on most cable I've ever heard of). The TV is useful for more than just watching cable or sports--if you are a gamer (or have a gamer in the household), or if you watch DVD's and want to get HD/Blue-Ray DVDs then a 1080p-quality TV is a must.
It's all about knowing how you are going to use it--if you are just going to watch TV for 2 hours a night on an HD DVR or live.... the 720p should do you fine. If you want to hook up peripheral devices (computer, HD-DVD player, console system, etc.) then the 1080p is an ideal choice for you.
202276
1080p is not necessary unless:
1) You want to use it as a computer monitor
or
2) You'll be sitting approximately two screen widths (or less) away from the screen and plan to stock up on HD DVDs or Blu-Ray discs in the next couple of years.
For a television, 720p is entirely sufficient, especially since there are no 1080p broadcasts and won't be for a very very long time. 1080p gives you absolutely nothing over 720p for watching DVDs. From, say, 8 feet away on a 50" screen, 1080p on an HD DVD looks absolutely identical to 720p from an HD DVD.
or
I pretty much agree with what is quoted--I differentiate between "ideal" (which I used) and "necessary" (which you used.) My personal opinion is that I should strive for the best I can afford at the time--others say buy what can be utilized out-of-the-box given existing conditions. My IDEAL situation is that technology will improve over the next year, so I purchase to meet those conditions.
I'm picky. =)
202276
I'm picky. =)
202276
.. What do you expect over the next year? ESPN and Fox to switch to 1080p??
You are some idealist ;)
Gotta' dream [H] and pray someone else out there does, too. :)
I bought a 720p/1080i TV 7 months ago, but my next TV will be 1080p (along with my next computer monitor, see my other post in this forum!)
202276
