5 x 120mm rad??
Is it still a 1/4" system? That rad would actually work very well in the room I keep my machine in IF it will take at least 3/8". It had also better have quiet pumps.
LunchboX3904 said:
http://www.thermaltake.com/watercooling/cl-w0040symphony/cl-w0040.htm
dunno how many ppl have seen this but wouldn't a 5 x 120mm radiator be a little overkill? especially in a home theater setup when you want as little noise as possible. lol......dual pumps too.
P.S. hehehe......"plug in, plug out" :p
1400 rpm is pretty low, i doubt you'd be able to hear much of the system running :p
I'd only be worried about vibrations.
