5:4 vs 4:3 Aspect Ratio
carbonsteel
Between the 4:3 and the 5:4 aspect ratio for LCD monitors, is there a difference in gaming? Thanks
Carbonsteel
5:4 would be more favorable for general use and 4:3 would be more favorable for gaming. 5:4 would only give you more space at the top and bottom, which isn't very useful in games, it's just a little more pixels for your card to worry about that you probably won't even look at. 16:10 is widescreen and is the best for gaming (If you're willing to edit some config files for games that don't support it).
