@soulesschild: yeah, I'll keep you informed/pics
Exhuast vs intake,
Some tell me that having negative pressure in the case is good. All fans blowing out, and letting natural airflow take it's place.
Negative pressure is definitely better than positive pressure, in terms of airflow. But you also want to have as much air moving across your CPU heatsink as you can. As long as you don't have too much negative pressure (only so much air will sneak in your case, it could stifle your CPU fan) and have adequate airflow over your CPU heatsink, you won't see a noticeable difference.
You need to get a door. Or do something with those white parts.
I have a door, it's just flimsy, so I took it off.
Gonna take out the white parts when I get my 3-bay intake.
Only thing is, not sure if it will work well if the CPU is on top, and the fan is on the bottom.
It will work, just not as well. The air will be slightly warmer by the time it reaches the CPU fan, since it will be traveling over some of the components inside before it gets there.
