even with three 2560 x 1600 monitors you'll still be missing over 16,000 pixels of detail, though it's unlikely one would notice, four 1080p displays will in total yield less than half the needed resolution
Thank you! Wow! that's not bad! and What video card would you suggest me?6x27" (2560x1440) would be extremely close. 2560x2 = 5120 (62 pixels short) and 1440x3=4320 which is more than enough.
So you would end up at 5120x4320. If you bought the Korean Ebay monitors you could get them for ~$270 each x6 = ~$1650. Not cheap, but it could be worse.
For camera sensors, a single component is used per pixel,
while monitors use all three color components is used per pixels.
(Note: a few sensors, such as "foevon sensor" (google this) can do all 3 color components per pixel. However, these camera sensors are not widespread, and is not used by your Canon) "
I'm not sure if I'd spend the money on buying so many monitors for pictures from a 60D...even with L series prime lenses.
I'd rather sell, then upgrade to a full frame camera (5D MK3, Nikon D800, even a used Nikon D700...etc), for overall better image quality then purchase more monitors.
But what is the purpose of needing to display all of the 18MP at once?
That's right.IIRC, the rating used by cameras that implement foevon sensors are generally x3 of the actual pixel count of the final image.
EG a 4.7MPx3 "actual" outputted pixels but sell the camera as a 14MP camera even though the final output is actually 4.7MP(given that each pixel consists of an RGB Value) They vertically stack the sensors to receive all 3 colors(RGB). 2 different ways of doing the same thing I guess. but informative post non the less.
So then 4x 27" lcd (2,560x1440) would suffice. This setup will achieve about 8MP, almost half of my 18MP pictures requirement, according to your research.That's right.
The Foevon 4.7MP (native) image is so sharp it is comparable to a bayer sensor 14MP (majority of cameras, including Canon), that they advertise the 4.7MP as 14MP. The sharpness is packed much more efficiently, with none of the bayer and demosiacing stuff. That's why I advocate a little bit downconversion (about 50%) at the presentation level for bayer images, so the OP with Canon doesn't need *that* much computer monitor to show off 18MP images...
If you're presenting, and going by my by recommended 2:1 factor (50% downconversion for bayer-sensor images), then you only need you only need half as many -- two 27" 2560x1440 monitors.So then 4x 27" lcd (2,560x1440) would suffice. This setup will achieve about 8MP, almost half of my 18MP pictures requirement, according to your research.
This achieves 11MP if you count all 3 color components (R,G,B subpixels):
2560 x 1440 x 3 = 11,059,200 per one 2560x1440 monitor.
If it is acceptable, yes.Do you really want to go for overkill?
Do you really need all 44 million subpixels for 4 monitors, for 18 million 'subpixels' (bayer sensor) of a Canon image?
On the other hand, are you trying to preserve the aspect ratio (by using a 2x2 array of monitors)?Definitely, I'm aiming for presenting only. I need to show off the pictures to clients, models, relatives' vacation or party pictures, etc.Are you aiming for editing, or are you aiming for presenting?
If you're just showing off images, you'll gain virtually no angular sharpness improvement (when adjusting distance for same FOV, e.g. adjusting your viewing distance adjusted for 30 degrees of FOV) for two versus three versus four 2560x1440 monitors, for 18MP bayer-sensor images. You may gain about 1% improvement in sharpness.
So your decision about going with 4 monitors probably should go with different factors:
There's another good reason for going with 4 monitors. If your images are 16:9, then using 2x2 monitors in a rectangular 16:9 array, will preserve the aspect ratio of your image. You can get quite close by using two portrait-rotated 2560x1440 monitors side-by-side, but if perfectly preserving the aspect ratio is important, then stacking your monitors 2x2 provides useful benefit. It consumes more space and expense, but if that's not important -- then 2x2 is fine. Overkill is good sometimes.
I would like the setup that gives the best possible aspect ratio to the pictures.
Wow! are you saying the I could get away with 2x 27" (2560x1400) in portrait mode?
I don't mind buying 4x 27" displays really; if I could get a better solution than the two in portrait mode.
It would not be a power point in company office kind of presentation to watch from 15' away. It will be from my desktop computer at home, perhaps from 3 to 5 people group.what type of presentation is it ?
You might be better suited with 4 of the samsung 4mm bezel LCD tvs, 1080p = 2mp, so 4 is 8mp, you get the size factor too
So do you think that 2 of these in portrait mode would suffice? Thanks kindly for such a great info.each 27" 1440p monitor is roughly 3.7MP, so 4 is actually 14.8mp, and overkill. 4 1080P TVS = 8MP
I mean is it to show potential clients your photography work? or is it a studio display for people visiting? showing your boss some pictures you took of people stealing crap?It would not be a power point in company office kind of presentation to watch from 15' away. It will be from my desktop computer at home, perhaps from 3 to 5 people group.
http://www.samsunglfd.com/solution/spec.do?modelCd=Samsung IDWhat model are these and what price are we talking about?
It would be better if I don't have to de-bezel them.
I think 2 in portrait would look bad, unless you are showing pictures in portrait, if you are showing the picture in a landscape orientation then 3 would be better for aesthetic purposes.So do you think that 2 of these in portrait mode would suffice? Thanks kindly for such a great info.
15' viewing distance changes everything -- totally.It would not be a power point in company office kind of presentation to watch from 15' away. It will be from my desktop computer at home, perhaps from 3 to 5 people group.
My photography work.I mean is it to show potential clients your photography work?
I don't want to go lower than 2,560x1440 resolution per display, otherwise picture quality would start suffering degradation. Remember I want to preserve as much detail as possible at once.or is it a studio display for people visiting?
not sure on the price, but I'm betting pricey, you can alternatively look at the consumer line of thin bezel tvs.
http://www.bestbuy.ca/en-CA/product...spx?path=e7fe5872c341919cb7ac79cded0ffcc9en02
http://www.bestbuy.ca/en-CA/product...spx?path=e2787047769f55b2b56934c6a35f4441en02
The viewing is not for 15' away. If that was the case I'd get a projector.Agreed. For 15' viewing distance 1080p is going to be fine.
And a single 1080p display is going to be far better for viewing than four separate monitors side by side. Those thick bezels running through the vertical and horizontal centerlines are going to be hard to get past. Not to mention you'll have to invest in some calibration hardware to make all four monitors match.
1. Is your priority maximum angular resolution at 15 foot viewing distance?My photography work.
No. It has to be from my desktop computer about 4' or 6' away.Is your priority angular resolution at 15 foot viewing distance?
No. Maybe I can go to 3K but not 20K.Do you have a $20,000 budget?
No.Do you have a room that can be darkened?
Thank you, no projector.If so, my recommendation is a 4K projector, a Stewart Filmscreen brand wall-mounted screen, and a Radeon 7900 series.
They'll show off your photography more than 100x better. GUARANTEED.
Example, Sony VPL-VW1000ES projector with 3840x2160 resolution, a 100 or 120 inch StewartFilmscreen.com screen.
The Radeon 7900 series supports 4K over HDMI, I think it can be adaptored to the Sony VPL-VW1000ES (need to confirm)
Ok, since at least 1 of the three prerequisites is not met -- and since you're also needing them at a desktop too -- then your best compromise is a 2x2 array. It's a flexible "compromise" -- it's desktop usable (you can sit in front of them), AND it's presentation usable (it's reasonably good looking and big enough at 15 feet distance). Go for a 2x2 array -- four display panels. Some brands of 27" monitors already have fairly thin bezels, choose such a model.
But buy all 4 monitors all at the same time, from the same brand/factory/revision number, with the same wear-and-tear on backlight (zero hours), manufactured nearly at the same time. Don't buy the panels piecemeal. You don't want different backlight brightnesses and different color tints from adjacent panels. You don't want to mix panels from different factories (even if it's the same monitor model) because they look "different" next to each other. Buy a spare or two. Panel arrays look best if the panels are all exactly the same, driven by the same firmware, with the exact same wear-and-tear on its backlight, and also calibrated (e.g. Spyder colorimeter) for best matching. If possible, drive all of the panels from the same graphics card, and if not possible, make sure your two graphics cards is an identical model. Then you can eliminate virtually all the visible differences between adjacent panels, and do all of this within a $3K budget. (You might need to go Korean, especially with good cheap 27" IPS panels). At cheap Korean prices, you have enough money left to buy a fifth computer monitor, to have a spare, just in case one monitor fails. Make sure the rear of the monitors is cooled reasonably well, perhaps with an additional small ultraquiet fan whenever you're not presenting, as multiple monitors can heat each other up, leading to premature wear -- especially if they're CCFL (warmer) rather than LED (cooler).
I understand it's for your photography work, but what type of work is it? are you a wedding photographer? a sports photographer? Nature?
depending on the type of photography you want display, different setups would work better, a thin bezeled TV (we're talking 4-6mm thick) would work well for wedding photography.
Option #2:Thank you for that observation, I'll try to get them in the same serial sequence of manufacturing if possible.
Option #2:
Two 27" 2560x1440 monitors on your desk --- AND --- a good 55" or 60" 1080p HDTV sitting next to your desk.
It's doable (just about) in under 3K. You can run multimonitor among all 3 displays. Use the two 2560x1440 for desktop work, and the HDTV for showing off. A well-chosen 1080p LED HDTV will look noticeably better at 15 feet viewing distance, if it has better color, which will be far more noticeable than the sharpness. There are many good 60" HDTV's for a hair less than $2000. If you calibrate properly, the pixel sharpness of a 60" HDTV can be matched perfectly with 1920x1080 output from a computer -- maxing out the HDTV's sharpness capability (will look much sharper than a Blu-Ray freeze-frame), perfect text, no fuzzy text, ClearType compatible. The Samsung 2011 UN55D6500 can be had for $1500 in clearout sales -- 4.5 star amazon rating -- or even buy the 2012 UN55ES6500 new online at the same price -- it is a 55 inch LED HDTV and works great with computers. Just spend a little time calibrating it. You got $1500 left for two or even three desktop monitors, plus the required cables and wiggle a new graphics card in too.
Why try to kill two birds with one stone (desktop viewing distance and presentation viewing distance), when your 3K budget can already buy separate displays for both?
Jack of all trades, master of none. Know what I mean?
Different tools work best for different jobs (desktop vs presentation).
You have enough budget to achieve a 'reasonable' best of both worlds!
You can run all 3 simultaneously in multimonitor mode, and then switch the same images/videos between big display and your desktop pair, and I think it's achievable on a single graphics card (I think -- need to verify)
What do you mean by bad aspect ratio -- are the pictures stretched, or are there black bars? What aspect ratio is your photography? 4:3 or 3:2 or 16:9?I already have a Samsung 55 HDTV 1920x1080 but some how I don't like how the pictures look like, bad aspect ratio
The aspect ratio is 3:2. I can change it in the camera to be 4:3 or 16:9 but this setting is not available in the automatic setting. I'd have to take pictures on manual mode only. I'm not that proficient on manual mode yet.What do you mean by bad aspect ratio -- are the pictures stretched, or are there black bars? What aspect ratio is your photography? 4:3 or 3:2 or 16:9?
Please tell me how. Thanks.If your photography is 16:9 and it's not filling your HDTV, then there's a setting that needs to be tweaked, or you're not playing your pictures full screen. I know it can be done properly. Also, calibration needs to be done to make the picture higher quality on that TV. (if things looks too bloomed, or shadowy, or dull, or overbright -- the Samsung Service Menu can fix these settings. It's like a Konami code you have to punch into a remote, to access a special adjustment menu.)
That's why I want to play with a multimonitor setup that would accommodate the 3:2 aspect ratios.Nontheless, it's a good idea to multimonitor your desktop with that big display -- that way, you can keep your GUI & menus on the desktop, and have fullscreen 16:9 preview on the HDTV.
There's a few ways to display a 3:2 image on a 16:9 display:The aspect ratio is 3:2.
Disclaimer: The service menu may void your warranty. Some of that may be in the fine print. That aside...looks too bloomed, or shadowy, or dull, or overbright -- the Samsung Service Menu can fix these settings. It's like a Konami code you have to punch into a remote, to access a special adjustment menu.)
