- Aug 24, 2006
I have recently purchased Creative 5.1 Inspire 5200 Speakers. Everything seems to be working fine except there is no output in it right rear speaker.
Creative 5.1 Inspire are packed with 5 satellite spakers and one big woofer. In the woofer there are those 5 speaker ports where can fix the speakers so whenever i fix a speaker in rear right port there is no output.
The speakers can be fixed in any port. My question is
1) Do i have make some settings in order to support 5.1 sound environment?
2) Does my sound card does'nt support 5.1? Since mine is INTEL 945 GNT Mobo which support Intel High Defination Audio so it should support 5.1 Environment.
3) Some people say that mp3, CD does'nt utilize all 5 speakers i should try some DVD with Digital Dolby Effect. I am totally confused.
4) Is that particular speaker port designed for some specific kind of sound format??
