Kaldskryke
- Aug 1, 2004
Simply put, I cannot seem to get the centre speaker of my 5.1 system to work.
I have Logitech Z-640 speakers, and I doubt they are the problem. I've plugged the centre channel into my discman and things have worked fine.
I believe the problem stems from either my soundcard or its drivers. Well, it's not really a soundcard. I use the integrated audio codec on my Asus A7V8X-MX motherboard, which claims to be a 6-channel system. It uses SoundMAX drivers, which I have updated to the latest version. I have my 'speaker setup' set to 5.1 surround speakers.
Basically, I thought I was not getting any sound whatsoever from the centre speaker of my 640's (unless I was using the Matrix button). After muting the other channels I noticed that I do actually get some output, but it's extremely quiet. When I use the Windows volume control, changing the 'center' balance has no effect, yet the 'lfe' balance does. Changing Lfe also increases the volume output of my subwoofer (which makes sense). Why would changing the Low Frequency Effects slider change the volume (from very very quiet to very quiet) of the centre speaker? It's as if all the data for the centre speaker is being sent through lfe. Using the "swap Center/Lfe" option changes things so that the 'center' balance does change the volume, but it is still far too quiet, and now changes the subwoofer.
I've contacted both Asus, SoundMAX, and Logitech about the problem but I have yet to recieve any support (after several days, too). The Asus support system seems to be completely dead. That's why I'm posting here.
Any ideas to solve this problem? If it really seems like the best option I have the money to buy a new sound card, but I was hoping to simply resolve the situation without spending money. I'm not an audiophile and the onboard codec is enough for me, if it would only work. Still, if it really is best for me to invest in a new soundcard, I would appreciate suggestions for a reasonably priced 5.1 compliant soundcard.
