Equalizers are generally line level devices, not speaker level devices, so there really isn't an issue of wattage(unless you are planning to disassemble your speakers and install the equalizer after the amplifier and before the speakers, which probably just wouldn't work). Where did you hear about that 6 watt rating anyway? I didn't see anything about that on the spec chart.bobsaget said:ok thanks guys!
Here is the real questions though...
They have a rating of like 6watts max to each channel or something... I have the klipsch promedia 2.1's thx. They are 35 watts each channel!
Do I just ignore those ratings?
