4way-SLI and 3 Monitors
Hey Guys
I plan to buy a High-Performance-System.
Case - I have not decided yet. There are not so many for EVGA Classified SR2 (suggestions would be nice)
CPU - Intel Xeon X5680 (2 x Processors installed)
MoBo - EVGA Classified SR2
graphic cards - 4 way SLI / 3 way SLI - Geforce GTX 480 Hydrochopper
PSU - 2 x Enermax Modul 85+ 1250 Watt
HDD - SSD Drive
BD-Burner - 2 x Plextor PX-B940SA
RAM - 16 to 48 Gigabyte Corsair DDR3-1600
Cooling - H2O cooling of course
I read a few threads about 4-Way SLI as well as this article
http://translate.google.com/translate?hl=en&ie=UTF-8&sl=auto&tl=en&u=http://www.hardware.info/nl-NL/articles/amdnampoZGSa/4way_SLI_GeForce_GTX_480_test/15&prev=_t&rurl=translate.google.com&twu=1
I want to know if it is worth buying 4 Geforce GTX 480 (MoBo: EVGA Classified SR2)
or should I wait for the Asus Mars 2 (Perhaps I would buy 2 of them.)
What about the performance (of 4way SLI) compared to 3 way SLI ?
Is there any 4way SLI - test available with EVGA Classified SR2 ?
Does anyone know an installation guide for setting up a multiple monitor system ?:confused:
Which cables should I use if I would use 4way-SLI and 3 Monitors ?:confused:
Greetings
Tiger144000;)
sorry cant help you but man you better fold on that rig, looks like a dream rig to me.
Fun build, I have something similar, but since your asking a few fundamental questions, I would suggest you start on a smaller scale first. The hardware your listing is for advanced users. And even if you have the money to burn, unless you know what your doing, you will not get any tangible benefits, and could get the same experience for much less money. Also as someone noted above, need to know what the computer is for, and what resolution are you running?
As far as multi-monitor, your fine, with at least 3 video cards you have 6 active DVI ports, so you can plug it in any of the cards. Just know the performance when not in SLI is routed per card, so lets say you have a monitor plugged in each card, then each card is responsible for each monitor, however once you enabled SLI, then the cards are synced to the primary monitor. Cables are standard, just plug the DVI cables into the graphics card. If your Monitor support HDMI, you can use that as well, but same principle applies. Radeons have Eyefinity, and can plug into 3-6 monitors, with DP, and or DP to DVI adapters per Radeon, Geforce's are currently limited to 2 monitors per card.
I'd use a Lian Li P80 with the SR2, but most cases that fit the SR2 are nice to begin with.
ps. No performance difference between 4 way SLI or 3 way, only use 4 if you need more monitors really.
Fun build ? I would not say that, because if you render 3D-CAD Simulations (ENGINEERING) you need a lot of RAM and at least more than one graphic card.
Oh and the my new highend-machine is used for CAD-Simulation, Games and Video Editing and other things (office, playback media,........)
I use FULL HD Resolution or higher
current system:
Mobo - Asus P6T7 WS SuperComputer
Intel Core i7-960 Processor (only overclocked for CAD-Sim.)
4 x Asus Geforce 295 GTX
This system is pushed to its limits and sometimes it crashes.
I asked a few fundamental questions because I wanted to know s.th about the performance improvement of 3 way sli compared to 4 way SLI, when using 3 Monitors.
Also I must admit that's the first time for me using more than one monitor.
I could be wrong on this, but it's my understanding that the only 4 way sli profile for 400 series cards is for 3dmark, and that no games or applications beside that currently bennefit from more than 3 gpu's. Someone please correct me if this has changed or is completely wrong. I'll try to find my source for this later.
Additionally, geforce cards, and sli, are optimized for fillrate, something important in games, and useless in cad, which relies on vector performance. You'd be much better off buying a single nice cad card, like one from Nvidia's Quadro series, than you would buying 3 or 4 geforce based cards. Additionally, look into benchmarks for Quadro SLI scaling, last I saw, sli only scaled in fillrate based applications, like realtime textured and shaded previews in 3D Studio Max.
That being said, it has been over a year since I've looked into building a performance workstation for CAD, but I don't think this situation has changed. I would srongly encourage you to look for benchmarks for your application comparing Geforce vs Quadro (vs Radeon vs FireGL etc) as well as SLI benchmarks.
current system:
I am not saying in a negative sense, but it is a fun build noneless, theres no real practical reason to go this route, unless you really want to. Its the same reason, there no practical reason to own a Ferrari, except that its a Ferrari.
You are correct sir, that's why I mentioned go for 3 way not 4 way SLI, and correct again. If its a work computer for CAD work specifically, one single Quadro would benefit you more than 4 GeForces. But if you game alot on the Machine, then the GeForces will suffice, but you will lose out on alot of optimizations for them. I currently do the latter myself, and use Desktop Graphics cards, but I don't work with CADs on a daily basis. *8 gigs of ram is my current sweetspot for speed and what apps require.
I do a little CAD myself. :)
0.0 I was not aware of that. I know what I'm doing for the next hour or two...
I see that my high performance machine will be still a dream.
Best that I use the following configuration (only for CAD and Video-editing):
Case -Lian Li PC-V2120
graphic cards - Single/Dual Nvidia Quadro
PSU - Enermax Modul 85+ 1250 Watt
HDD - SSD Drive
Maybe I should use my current system for normal applications (games, office, ...).
Okay guys
Thank you for your help!;)
HDD - SSD Drive
Okay guys
NP, and good luck,
One of these days, I am going to try to get my hands on a recent Quadro and see how they stack now, etc and do a hands on test.
Here's a brief I found at Tom's. Not much, but it's a start.
http://www.tomshardware.com/reviews/quadro-fx-4800,2258-10.html
