sitalchauhan
- May 30, 2006
On the PSU there is an 8pin rectangular connection and a 4pin square power connection.
On the Asus P5K there is an 8pin rectangular power connection in the top-left of the board. However, 4 of the pins are covered by a plastic cap leaving only the 4 pins in the square arrangement (the plastic cap can be removed),
Am I supposed to remove the plastic cap and insert the 8pin connection?
Or am I supposed to leave the plastic cap in place and only plug in the square 4pin connection?
Here is a picture showing both the 4pin and 8pin power connections that I am referring to:
http://www.overclock3d.net/gfx/articles/2006/11/23201638654l.jpg
(I think they are called the P4-12v (4-pin) and EPS12v (8-pin) connections)
Thanks
Thanks
