This is what he said when I asked him about it... " I think its the used for the Gfx cards if your power supply isnt SLI compatable, they suppulied a jumper for it. but if your ps is SLI compatable "DONT USE IT" it will fry your gpu and PCI'e pathways. "Skolar said:Unless I'm mistaken, its for the motherboard. They have become more power hungry. I think DFI just abandoned the 4 pin and went to an 8 pin connector right next to the main power connector on the mobo. I'm pretty sure you have to have it to boot to. Had he tried to boot without it?
Rock on man. You're totally safe. He seems to not have good information on this one.§·H·ï·Z·N·ï·L·T·ï said:This is what he said when I asked him about it... " I think its the used for the Gfx cards if your power supply isnt SLI compatable, they suppulied a jumper for it. but if your ps is SLI compatable "DONT USE IT" it will fry your gpu and PCI'e pathways. "
That can't be true because on my SLI powersupply I have it connected and have no problems at all these last 4 months.
