Picked up a Seiki 39" 4K monitor a while back, so figured its time to get a new setup which can hopefully last a few years and can support gaming at 4K. Haven't been following the different iterations of processors / graphics cards etc so am somewhat lost..
Web browsing + gaming, at 4K. No FPS though, mainly RTS / WoW, Simcity.
No fixed budget but would like to keep things somewhat reasonable, hopefully somewhere around $1000 all in, but stretching is fine if necessary.
Singapore, but ordering from Amazon / Newegg is fine.
CPU (and cooler?), motherboard, RAM, graphics card, PSU, case. Am hoping for a slim tower mATX (or even ITX, if everything can fit) case.
SSD and HDD, input devices, optical drive.
6) Will you be overclocking?
No.
4K 39"
Next couple of weeks, no particular urgency though.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Probably only USB 3 to download photos, SATA 6gbs.
Windows 7 64bit, wondering if Windows 8.1 is worth the hassle to learn and the additional spend.
No.
4K 39"
