4K for Xbox 360?
PCunicorn
I was wondering, should I get a 4K monitor for my Xbox 360? I can get a really good deal on one, so dont worry about price. Will games look any better at 4K on console, or exactly the same as 1080/720p?
they get dumbed down to what ever the output of the 360 can handle.
I would say the best is 1080P but maybe it will look sharper?
It wouldn't look any different than a 1080p monitor. 4k is just 1080p x 4 so each pixel represented will be 4 pixels instead.
Keep in mind though that 99% of games on the Xbox 360 is less than or equal to 720p
Okay, so pointless to spend a penny more on a 4K TV for only a Xbox 360 then?
I say go for it, even though the 360 won't take advantage of it, at least your screen will be futureproof once 4k content becomes more widespread.
Next question is; does a 4k tele scale 720/1080 to 4k? Kinda like how dvd looks better when scaled to 1080p on a good tv or bluray player.
Better wait for next gen screens with hdmi 2.0
The Xbox 360 does not support output at 4K resolution. Even if it did, I would imagine that the upscaling to it would look pretty bad when most games run 720p natively.
Supported TV Resolutions
  • 480i
  • 480p
  • 576i
  • 720p
  • 1080i
  • 1080p
Supported PC Resolutions
  • 640x480
  • 848x480
  • 1024x768
  • 1280x720
  • 1280x768
  • 1280x1024
  • 1360x768
  • 1440x900
  • 1680x1050
  • 1920x1080
4k @ 30hz or 60 hz?
There were a lot of cheap 4k TV's in the past year that only did 30 FPS.
4k will not be mainstream for many years. Buying a model now to "future proof" is foolish because by the time you need a 4k display, much better models will be available for equal or less money.
If a TV does do fancy upscaling it will likely introduce extra lag in order to process each frame of video before displaying it. I expect the average 4K TV is worse for gaming* than the average 1080 TV.
*below 4K resolution.
