Depends - it's the same PPI as a 24" 1080p monitor, so if you can read text on that you should be fine.
I have a 40" 4k monitor and I'm using 150% scaling at ~80cm distance. Bigger text is easier on the eyes, but it really depends on personal preferences and how close you sit to the screen. If you ask me, 1440p is perfect for 32".
