i recently bought a gigabyte 7600gt with silent pipe cooler ... i wanted to pull the cooler off and mount a low profile maze4 gpu block to it. I wanted specifically to be able to use the four way mounting holes that uses the danger den acrylic four way back plate...
Once i got the stock cooler off it looks like a two hole design .. the are four holes but they are too close together to use the dd maze4 4way.
Can anyone confirm that a 7600gt pcb design exists that can accept a danger den maze4 gpu four way mount?
thanks,
mal
this is the one i have
want to be able to use this thing
thanks,
mal
the holes that exist on mine are two wide ones that fit two of the four holes on the acrylic dd top .. (basically it's a standard 2 hole design)
