eva2000
- Apr 14, 2002
Some folks say 4x1GB has issues on 680i boards for orthos blend test. So thought I'd try it out
4x1GB G.Skill 6400PHU2 2GB HZ Micron D9GMH 629 batch for the first time on Asus 680i Striker Extreme.
System:
Settings used:
Using Orthos Blend for short duration tests due to time constraints.
System:
- Intel Core 2 Extreme X6800 L627A872 B2 Step 6
- Swiftech Apogee/Radiical Triple Fan Single Pass Rad/MCP655 + Kayl 100W Custom PSU
- Asus 680i Striker Extreme 0402 bios
- 4x1GB G.Skill 6400PHU2 2GB HZ Micron D9GMH 629 batch
- 4x80GB Hitachi 7K80 SATAII Raid 0 on SATA3 to SATA6 ports
- Pioneer DVD Burner
- 600W OCZ EvoStream
- @400mhz 4-4-4-12 5-22-6-8-42 at 2.15v vdimm
- @480mhz 4-4-4-12 5-22-6-8-42 at 2.20v vdimm
- @500MHZ 4-4-4-12 5-22-6-8-42 at 2.25v vdimm
Settings used:
AI Tuning: Manual
Nvidia GPU Ex: Disabled
LinkBoost: Disabled
FSB - Memory Clock Mode: Unlinked
x FSB - Memory Raio: N/A
FSB (QDR), Mhz: 1067 (means 266FSB)
Actual FSB (QDR), Mhz: 1600
MEM (DDR), Mhz: 800 and 960 (means 400mhz and 480mhzmhz speeds)
Actual MEM (DDR), Mhz: 800 and 960
Vcore Voltage: 1.325 set (1.24v bios - 0505 and higher bios fix the vcore issue but 0402 bios more stable for both my E6600/Q6600 cpus. Have not tried 1002 bios yet)
Memory Voltage: 2.15v and 2.20v respectively
1.2v HT Voltage: 1.30v
NB Core Voltage: 1.55v
SB Core Voltage: 1.50v
CPU VTT Voltage: 1.3v
DDRII Controller Ref Voltage: AUTO
DDRII Channel A Ref Voltage: AUTO
DDRII Channel B Ref Voltage: AUTO
tCL (CAS Latency): 4
tRCD: 4
tRP: 4
tRAS: 12
Command Per Clock (CMD): 2 clock (2T)
Advance Memory Settings
tRRD: 5
tRC: 22
tWR: 6
tWTR: 8
tREF: AUTO
tRD: 7
tRFC: 42
Async Latency: AUTO
CPU Spread Spectrum: Disabled
PCIE Spread Spectrum: Disabled
MCP PCIE Spread Spectrum: Disabled
SATA Spread Spectrum: Disabled
LDT Spread Spectrum: Disabled
CPU Internal Thermal Control: Disabled
Limit CPUID MaxVal: Disabled
Enhanced C1 (C1E): Disabled
Execute Disable Bit: Disabled
Virtualization Technology: Disabled
Enhanced Intel Speedstep Tech: Disabled
LDT Frequency: 5x
PCIEX16_1 Frequency (Mhz): 100
PCIEX16_2 Frequency (Mhz): 100
PCIEX16_3 Frequency (Mhz): 100
SPP<->MCP Ref Clock, Mhz: 200
