I have 2 cards - Sapphire 4890 Vapor X Toxic edition running at 1020 GPU & 1150 MEM for about a year without isues. (base 960 GPU & 1050 MEM) co I OC'd it) I don't want to upgrade them as they work but I thought about adding another card.
Does the additional card have to be the same?
I know it has to be the same serries but exactly the same version?
I found a 4890 Vapor X (not the Toxic version) base GPU 850 & 975 MEM.
Can I add this to the crossfire or can I add it as a PHYSIX card?
Or does anyone know where I can get the Toxic version so I can add it to a tripple crossfire? I
f not and I can add as a PHYSIX card can anyone tell me the best way to do it with instructions
or to just avoid the entire thing since it's not worth it.
The card I found is priced at $72
Else I will wait a few more years and then upgrade the entire system.
Does anyone know?
Thanks in advance.
Does anyone know?
Thanks in advance.
