4890 and 4870 CF worth it?
dasfool
Would it be worth crossfiring a 4890 1gb with a 4870 1gb or would the 4890 just clock down to 4870 speeds? I've been trying to find information about this, but have been unsuccessful.
In any valid Crossfire or SLI setup with mismatching speeds, the faster card clocks down to the speed of the slower card.
Why does CCC allow for individual gpu tuning then?
I guess basically what I'm asking is if the 4890 would just end up acting like another 4870 while crossfired to a 4870, thus making it overpriced in that kind of setup.
Nope. Total waste. 4870 will hold that 4890 back in every way possible.
Good luck overclocking the 4870 to 4890 speeds.
its not that hard, i have my 4870 running over 850Mhz with no voltage adjustments. i'm sure its a tad slower thanks to any improvements in the 4890 but i bet its not that far off....dunno how the stock cooling would handle it though; i got it on water
if ur 4870 hits 4890 speeds and is a 1gb, it would be a good way of ensuring you get another card capable of the same. If its a crappy clocker, prolly not.
I think it would def. be worth it....I mean, who cares if it matches the 4870 speeds...
4870 X-Fire> 4890
Just keep in mind you have a board that has 2 PCI-e x16/x4.
