Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I am swapping my 4890 for a 5450 because I never play games and the 5450 is silent and uses much less power. My only concern is 1080p movie playback with VLC. Will I notice any difference?
I think the 5450 is too weak with only 80 Cores, the 6450 is a much better choice IMO with at least 160 cores and will provide better image quality too!
WOw what a difference. Originally my 2500K @ 4.5 Ghz and 1.4V would hit 70C under load with a Noctua cooler (no other case fans). I returned the CPU to stock speed at 3.3 Ghz and undervolted to 1.1V and it cooled to only 56C at load. Then I took out my 4890 and put in the 5450 and now it hits only 51C under load. Awesome! feels good to use less power.
