4890 2gb in crossfire
harlock328
Hi,
Does anyone have 2 vapor-x 4890 2GB in crossfire? If so, what MB are you using. 2 don't fit on EVGA's E758-TR. Backside memory heatsink hits the other card. :( just got the MB so I can return it, just need to know which one to get that'll fit two of them.
Thanks
I think finding someone with that exact setup maybe difficult.
That said, I'm using two Toxic 4890s on my P6T Deluxe V2, and they fit fine.
Hopefully that is of some use.
i have 2x HIS 4890's in CF and im using a G-B MA790XT board and they have 'at least' an inch between each other
My boss is using to on both a Gigabyte X48 DS-5 mobo and I believe on his Gigabyte EX58- UD3R They have a decent amount of space on the X48, not sute on the other one.
Just read the reviews on the motherboards or download their instruction manual. Usually they will list how much space is in between slots or someone will comment about it in a benchmark review.
Thanks everyone for the replies. The vapor-x 2gb is unique sine it has memory on the backside with heatsinks that stick out. The heat sinks hit the first card on my MB. the Deluxe looks like it will work. I checked x58 mb reviews and haven't found any actually have measure the space between pcie 1 and 2. Sapphire tech doesn't know which boards will work, they only tested them on AMD boards not any X58 MBs :(
Thanks again for the replies.
