4870x2 Screenshots COD4 for those with issues (large pics inside)
Putz
I have a custom title
Had a few people ask for them
1920x1200 8x AA (24x edge detect) 16x af max EVERYTHING, i use some of the harder scenes for the shots instead of the indoor ones which are pretty easy to get 200 fps on even my old single gtx 280
keep in mind this is the all ghillied up level, other area play around 150+ fps, this map makes the fans spool up pretty good :)
the fps doesn't change much disabling crossfire, 5-10 fps seems to be the norm, i am however leaving the multiple graphics cards option ON
couple questions:
1) How do you get that fps counter on the top right?
2) does cod4 have a built in screenshot, or r u using fraps?
3) in bog_a or bog_b, what are you fps's
4) did you just keep the multipe cards option on while playing with 1 4870 x2, or were you running both?
lol i think people are over crysis, i only posted mine before people were having issues with COD4 and the 4870x2 cards and poor fps :)
also 6.5 mb bitmap is probably bad idea... in forums lol
couple questions:
1) enable console in options, \cg_drawFPS 1
2) built in SS i think it reduces the image size alot, the game looks better than the shots but i wanted to get the fps across anyways
3) ill have to get to bog, i just reloaded the computer so i lost my save games, i think all ghillied up work the card harder with all the shaers, but idi get to bog tonight ill get some SS's
4) i left multiple cards option on for BOTH (2gpus and 4)
there's a couple from bog (4 gpus)
funny enough with 1 card (2 gpus) half the screen shots are black, with all 4 gpus 3/4 of black, wonder if the screenshot utility only captures images form the primary gpu
bog is a bog indeed lol
you dont have to get bog :) just open console and type map bog_a for the one thats at night and starts with the streets, defending the tank, etc. And map bog_b for the day one thats after you get the tank and move through the city. But you can test them tonite, i need to start/finish both my essays for school that are due on thursday anyway..
Yeah took it off, but sure was purdy.
yeah crysis does look great and with the patch and very high everything the physics and stuff is very cool, but the game gets stupid after the half way point... im sure if the optimized it alot more it would be fun multiplayer
what are you using for screenshots? the build in COD4 ss converts them to crappy jpegs and doesnt look as good as the game
Using fraps it gives options : jpg, png, bmp, and tga
thanx, im about to retest bog with the same settings as you, just at 1280 x 1024, and according to a bunch of reviews i should get around 10 frames more. But for the bog shots, you were using both 4870 x2's right?
yeah was playing with fraps but all the shots seem to have messed up shadows
yeah i loose about 5-8 fps in the bogged down slower areas where i was getting 65-80 with both cards, in "quiet" ares of bog its well over 200 in the house etc with nightvision, so there is some benefit to 2 cards at 1920x1200 might not be much though :)
kk im going to run it forced 24x CFAA and 16x AF with Adaptive AA at quality and see. Then ill go finish my essays or get close to so i can bring my comp down tonite and test it on the 52" bravia :)
well after an hour and a half i finally got it running over component. no sound, but the video was fine, so i set it at 1920 x 1080. All max in CoD4 24x CFAA and 1x AF like you.
My frame rate was like 40 frames on avg i believe, like during the beginning with the all the gun fire, fire, smoke, etc.. i only had like 10 min of testing till my dad wanted me to bring the comp and go to bed. he said he'll order my monitor/display soon, like within the week hopefully!
Anyway, my frames were freaking crap, i may have done something else wrong, but i know all CoD4 settings were on max, forced 24x CFAA, 16x AF Quality Adaptive AA, 60 HTz refresh rate (said that in CoD settings). Or are 40 frames on avg. good?
Time to tell Dad, "You know you're alright. I think I'll keep you." :p
haha, i've waited months for it. and what pisses me off, is that he didnt even think i should get a 2k monitor even though i waited for a yr and a half cause my mom says its spoiling me. So i flip out and say i waited so long, and its not like moneys an issue, and they say we know, but for a 14 yr old its too much...But i usually get it since i usually do pay part :) but waiting is like fucking hell, and the worst part is that in one week my freshman yr begins and im all honors, doubled up with more honors. im taking the highest classes all 4 yrs, and they still think aftere waiting for 18 months, paying 1000, and doing all this there spoiling me haha
but again, after i get the monitor, your right, ill be like your freaking awesome! :D
My youngest was an honor student and very spoiled. :)
gonna print that out, go to my parents and cry, telling them how other kids get all the cool stuff, and i only get crap.
Eh, scratch the crying part. And, if i do get everything i planned for my new build, to hell with all the complaints :D
Hope you get what you want Speedy. My son would go nuts for all that, but then again hes not an honour student + I can hardely aford my Pc upgrades as it is so hes stuck with getting my old pcs for now LOL
He cant really complain though. Sure he doesnt have the best of the latest in everything, but he does have my last pc wich was high end a few years back :)...and has had all consoles upgrades since he was old enough to play them and we think hes a bit spoiled sometimes too even though he doesnt think so hehehe
