I'm experiencing freezing issues when playing Fallout 3 on the first system in my signature. The game will play okay for anywhere from 10 minutes to hour then just randomly freeze. Music continues but everything on the screen is frozen. I use control alt delete to bring up the task manager and it takes a couple of tries to shut Fallout 3 down. Task Manager indicates that Fallout 3 is not responding.
The 4870x2 is a new card and the only other game I have played is TF2 which also has some stuttering issues but no freezing. I run TF2 in 2560x1600 so I know I am pushing it there which could cause some stuttering.
Fallout 3 is run with medium to high settings in 1920x1200. I originally had issues playing it on a Vista 32 bit system so at the recommendation of a friend, I moved to Windows 7 64 RC1 about two days ago. The same problems are occurring. I am running the latest version of ATI drivers, 9.5. I do have a question here though. When selecting drivers for Windows 7 64/4800 series card, there are several choices for downloads. I understand that the first 2 choices are packaged while the bottom choices are individual components. However, I am still wondering which of the first two choices I should choose. I picked the 1st one that stated it was version 9.5 which was released on 5/15 but the second choice, version 8.612 released on 5/5, is 35MB larger. Am I supposed to download both? They both state they are the display driver, catalyst control center and ATI WDM integrated driver. However the description under the download button for the 1st choice states it is the Catalyst software suite while the second one states it the Windows 7 64 WHQL driver. So, do you install both, just the first, just the second or what? It's my understanding that 8.612 is the official driver number for the driver included in the 9.5 package so I'm confused.
I have run 2 instances of GPU-Z in the background, one for each chip on the video card, and find no anomolies/strange temps/etc to indicate a problem with card. The card is an ASUS 4870x2 tri fan which seems to do a great job at keeping the temps low.
Just test 3dmark Vantage and it froze after the two video tests and before the cpu tests. I have overclocked my Q6600 to 3.15 but the temps are staying under 60C. Would memory be causing a problem? I have it set to the voltage and timings listed on the package. Ran the Intel Burn Test 25 and passed.
Any insight or guidance in troubleshooting would be appreciated.
