4870x2 CCC Default Fan Profile
EscaroN
I created a custom profile through CCC for my desktop when I'm not running any games and set my fan to Manual with percentage of 35, this seems to get my idle temps down to ~55C which I'm perfectly fine with. I would like to create another profile though, for when I do want to play games and have it so that CCC will control the fan speed itself, ie. increase and decrease it based on GPU temperature and load rather than always keeping it at 35%.
Is it enough to create another profile while my desktop one is loaded and simply alter the xml to Automatic instead of Manual to make sure that CCC controls the fan itself. The reason I ask is I want to make sure that if the card does start getting hot when I play games that CCC will take the fan percentage above the 35 that I set it for.
Thnx for the help
Are you using the official 8.8?
Cause I can't find the user profile directory anywhere...
Nothing under my user-name in Vista.
