4870x2 + 4870 1GB
XNeKoSX
Maybe its me but I think I may have stumbled upon something here. Wanted to see if anyone else have noticed anything.
After noticing my 4870x2 crapping out at 70 degrees and and higher, I replaced all thermal compound with Artic Silver 5. I did notice a 5 degree lower difference but was still getting hot and the fan cranked up to 70%.
Now its been a week and I have added a 4870 1gb to my system ( triple Crossfire, if you will ) I have noticed my temps for the 4870x2 drop. All core temps all both cards ( 3 cores ) are in the low 40's. and under load does not reach over 60 with fan set at 50%
Now what I am thinking here is, I believe the 4870 1GB has taken some of the load off the X2 which would actually lower the core temps since they are not doing all the work.
Would I be correct??
To me that seems like the logical solution... Perhaps the 4870X2 is offloading the less-intensive tasks to the 4870, which would lower the temperatures on the 4870X2. Such a phenomenon would also raise the temperatures of the 4870 itself, but being a single-GPU card, it'd be a little bit harder for it to approach critical temperatures with just a little bit more load on it.
Adding the additional card could also have affected the air flow of your case.
It could have directed the air flow from the middle case fan to a more direct flow into the card but I am more inclined to think the single 4870 is acting as offload card in crossfire for the X2
All the cards are in the low 40's.
Hmm you both make good points and I am thinking that the 4870 card took some of the load off the 4870x2 but also it is possible the the air flow has been redirected ether way it looks like it is a win win situation......
I will say yes, it is a win win situation for me.
Some advise to all.
If you plan on doing triple crossfire, Quad Crossfire, and probably even 3 SLI, use 64bit OS. 32bit just has problems with this type of setup, well I did. XP and vista 32bit just kept causing weird crashes and crossfire would work then not work, card was seen then disabled then not seen. 64bit installed, everything is working like a charm.
Now for my upgrade to Core i7, X58, DDR3 1600 setup.
If you're really using an E6600 at stock, I believe that's why your X2 is getting cooler. You wouldn't have enough CPU to keep 3 GPU's fed.
not to hijack your thread but what's your impression of tri-fire ? Thinking of adding a 4870x2 to my 48701gb,when i got to i7 that is
Tri-fire is impressive. My games are that much smoother and I guess you can say, I am ready for anything new that wants to tax my system in the detail catagory.
I wish I had one of those myself, it would be boring not having much if any game out there to be deemed a worthy opponent to test that machine :)
im not sure running a 4870x2 along with a 4870 is going to give u effective tri crossfire.
its like running a 4870 and 4850 together. the 4870x2 will only work as fast as the single 4870.
anyone else know for sure?
Running TriFire works. The key is he's using a 1GB 4870. I think techreport had some benchies of 4870x2+4870 and at times it ran faster than 2 4870x2s
As stated above, the trick is to use the 1gb version since the x2 is technically 2 4870 1gb versions. I am keeping with the format of the cards. if I added a 512 verison then yes, i would actually be degrading the ability of the x2
