I was having trouble with the same decision a few days ago for my next build. I went with the 4870x2 because of power consumption (even though I went with a Toughpower XT 850, this will be the last PSU I buy in a while) and the fact that the 4870x2 doesn't take up 4 slots like a SLI setup.
im getting this with an antec 900 II so i dont mind take it up a slot or 2, especially for 2 of these babys:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150330
Whatever floats your boat. The advantages are marginarl but they are there. Is it worth it for you for the next few months? I don't know, your wallet dictates that. But yeah, the 260s will grab you a few more frames/sec. But, even with an antec 900 (Which isn't even a full tower) you are still limited to 7 expansion slots. You may need those extra PCI ports, you may not.
Actually, now that I'm looking at the benchmarks again, the only game that the 260s beat the 4870x2 in is Crysis. But, Crysis has always been biased towards Nvidia. So yeah, after taking another look, definitely go with the 4870x2.
You can also go Crossfire X4 with the addition of just another 4870, only requiring 4 slots vs a GTX260 x4 setup that can't be done (without single slot coolers).
Looking at various benchmarks it looks like the 260 SLI setup edges out the 4870x2 except in games that are already in the 100+FPS range. The 260 SLI setup can be had for a little cheaper as well. Of course, you do have to be ready to put up with the extra heat and power consumption as well as the used up PCI slots.
well the 4870 x2 gets pretty hot itself i heard and indicated in alot of the newegg reviews. it can overheat sometimes too.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102768
but for future proofing wouldn't a sli gtx 260 setup be best?
No, a dual 295 setup for the sake of future proofing is foolish right now. DX11 cards are coming out within 4 months.
I just googled 3 reviews on the 4870x2 vs 260 SLI and the only game in all 3 reviews where the SLI setup beats the 4870x2 is Crysis. I'll post them if you don't trust me.
The 4870x2 may get hot but a single 260 will produce about 80% of the heat of a 4870x2. Add another 260 and you have quite a space heater.
4870X2 is my vote, awesome card. Why needlessly deal with running 2 cards, having double the amount of problems that can occur or fans die and deal with overclocking 2 separate cards, when you don't have too =)
My buddy IRL may give me his 4870x2 when he upgrades to dual 4890's (he is insane with spending monye on comp upgrades). I am looking very forward to it!
ATIs drivers right now are just as good as nvidias btw. They work fine. Last bug I had with them was fullscreen flash crashing the video drivers, but that went away several versions ago. Perfection since! And you dont need to install a giant 60mb overclocking download just to bump up the core/mem clocks like you need to on nv drivers now
Wouldn't matter either way. A single 260 can run all those games on the highest settings at the highest res. My 7800gtx can do css, and comes close for bf2.
did anyone else notice his screen name?
