4870 x2 compatible with 790i ultra
Crippy144
I bought a 4870 x2 video card and I have a evga 790i ultra mobo. Will I have any problems with e 4870 x2 video card working? Im not gonna run two cards just the X2 by itself. Will I have any problems with the video card not working or is that only with 2 4870 x2's??
please help
I had this mobo before i purchased the card. I bought one 4870 X2. I just want to know if it will work fine; im not linking two of them. Will I get the full potential since im using the 790i ultra if the card does work (both GPU's)?
I didnt think about this until i purchased the video card.:mad:
So the Crossfire is software run instead of hardware since im only running one card? I have a full liquid cooled system and its alot of work taking it apart especially if the video card wont work.
Work as in display screen and both GPU's run at once instead of just one of the gpu's. Im going to upgrade to a i7 soon, but im want to use my Q9450 a bit more since its still a beast.
system specs just in case are
evga 790i Ultra
intel Q9450 2.66 @ 3.6ghz
ocz DDR3 1600@1800
Corsair 1000HX PSU
Hang on a sec, you have bought the card and only now asking if it will work?
Anyway, yes it will work in any compliant pci-e slot.
It's not software CF it's just native CF on the card between 2 GPU's. It works, no matter what, both cores and everything. =]]
