4870 stock fan oc ability?
lifanus
Hi,
I used the ati CCC to automatically adjust the core and mem frequency and it ends up stable at 785 core and 1090 mem. temp shows idle at 49 degree, full load at 59 degree, with fan speed manually set at 30%, is this normal? Do you OC your stock 4870 beyond 790/1100?
while i did turn up my fan speed because i just am not comfortable leaving my gpu running so hot by default, i do not oc my video card because as a general rule it only nets you 3 or 4 fps on average and that just isnt enuf to justify all the work that goes into it.
just my .02
3 to 4 fps is a big deal in Crysis when the fps are low anyway, but not for any other game really. That said, you should be able to break 800mhz without breakin a sweat. Mine is stable at the max that CCC can handle. Havent tried anything higher since I dont have the need.
just my .02
Moving those two sliders is quite the workout isnt it? :D
Hi,
First of all, please read this on autofan control as it will give you better results IMO.
OC mileage will vary no doubt. I was unstable at 820, but not below, and had instability at 1150 (1125 was stable), so for pure safety sake I have left it at 800/1100 and have had no issues. My idles and loads are higher than yours, but the fact that I live in Rio de Janeiro unquestionably has a lot to do with that. My idle fan is also at 30% and load fans range from 34-42% depending on the GPU temperature.
No kidding, especially with a 4870 where the memory OCs so much so easily. My non-OCed GPU score in 3DMark Vantage was about 8350, and my OC score is 9150. No big temperature increase (2 degrees), no danger to the card, and a free increase. What is not to like?
It is much like my CPU. I could leave it at its 3.0GHz, and have already OCed it beyond 4GHz, just to test and see the benchmarks. 4GHz require increasing the voltage to 1.35v (from vanilla 1.25v) and caused a very significant temperature increase. I settled on 3.6GHz which I could attain with no voltage increase, and only 2 degrees temperature change. Tested on idle and load. So basically I get 20% for free. Why on earth would I not choose this if it is essentially riskless?
