I want to get a 1Gb 4870 card for my new rig but I dont know which to buy. Or should I wait for cooling to improve on them?
Heres my planned rig:
3.16 ghz core 2 duo
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115036
motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128345
4gb ddr2 ram
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145184
case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811156078
Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371015
640 Gb hard drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148335
Optical Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106228
Extra case fan:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811998102
Windows Vista
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116488
I was thinking about going with sapphire and this card: http://www.newegg.com/Product/Product.aspx?Item=N82E16814102795
In added the extra case fan to try and help the cooling but I'm unsure about which brand/card to buy. Any help is appreciated. (btw I'm probably going to switch to a cheaper plain fan because I dont need prettyness in my machine)
3.16 ghz core 2 duo
motherboard
4gb ddr2 ram
case
Power Supply
640 Gb hard drive
Optical Drive
Extra case fan:
Windows Vista
