Hi yall,
I bought a used computer that already had a 4870 video card in it. I have several issues with the card. First thing, I noticed it has (2) 6-pin power slots but the PSU only has 1 6-pin adapter. Does this mean it is not getting its appropriate power requirements? I ask because sometimes when I turn the computer on, there is no video input on the monitor. Once in a blue moon it will but most the time it won't. Another issue, on bootup the fan is very very loud. It reminds me on the old Vantec tornado fan I used to have. I assume that during idle it is not as loud, but is it going to be that loud during gaming? Is this something I can change with the ATI control panel (turn the fan speed all the way down). If not, should I just replace it with a quieter 4850 or get some sort of quiet aftermarket cooling? Lastly, gaming at 1680x1050, a 4870 is > 4850, right? Or will I not notice it until I get to higher resolutions?
Thanks!
Thanks!
