4850
The 4870 512mb is pretty much faster than the GTX 260 vanilla in just about every game.
The only time the 4870 512mb was faster than the 260 vanilla is when using 8xAA, and that changed with the big bang drivers. The vanilla 260 is only 4-5 FPS slower than the core 216 version, so that pretty much makes the 4870 512mb the worst of the bunch.
I just picked up a GTX260-216 from Newegg this week to replace my 8800GTS, going to install it tonight. Any recommended drivers I should get for this card? WHQL or Beta?
clearly a driver problem or some other system componenet problem that didnt like the ATI card, even though you say its not a driver. 2 cards are pretty much identical in power, issue is on your end.Just to throw my two cents in here.
I had been using an ATI 4870 512MB for a few months now, well since about August. I just bought an XFX GTX260 Black Edition the other day and the difference is HUGE!. I don't mean a few frames more here and there. I mean Fallout3 went from a stutter-fest to smooth as butter. I was also able to increase the AA from 2x to 4x at 1920x1080 and it was still smooth, with no stutters and fast framerates on my GTX260.
That's not to say the 4870 is not a good card, it is. I used it for months and had little-to-no problems with it. I will go ahead and say that I do prefer Nvidia's drivers to ATI's though. Just a personal preference.... well, that and after installing 8.12 Catalysts my system would BSOD on boot about 75% of the time.... :\
4850
doesn't gtx260 have better minimum fps most of the time? that matters to me the most.
http://enthusiast.hardocp.com/article.html?art=MTU3MSwzLCxoZW50aHVzaWFzdA==
http://enthusiast.hardocp.com/article.html?art=MTU4Nyw1LCxoZW50aHVzaWFzdA==
http://enthusiast.hardocp.com/article.html?art=MTU5Niw1LCxoZW50aHVzaWFzdA==
http://enthusiast.hardocp.com/article.html?art=MTU2NCwzLCxoZW50aHVzaWFzdA==
http://enthusiast.hardocp.com/article.html?art=MTU4OSw1LCxoZW50aHVzaWFzdA==
Lower min framerate or not, the games are playable at those settings. You don't need to mess with the driver if you don't want to, a newer driver would probably just give a better performance, it's not like you can't play the game with an older driver.
They all look pretty even to me. It looks like Fallout just poops in the mouth of all the new cards. That's what I was playing yesterday to see how the 9600GT would keep up. I left everything on high as it has been, but cranked up the resolution on the crt to 1900x1400 or something like that. I didn't make an excel spreadsheet or anything, but it looked like the fps would dip down into the high 20's and peak in the low 60's, with an average in the high 30's/low 40's. It looked like shit, choppy as hell, and that's not far off of what they were getting in the review. Mind you, my 9600GT has a pretty impressive overclock.
9600GT and GTX 260 or HD 4870 is like night and day. 9600GT only has 64 Unified Shaders, GTX 260 has 192 Shaders and the faster version has 216 Shaders.
At stock the 9600GT has a slightly higher clock speed, unless your 9600GT has more than twice the stock clock speed, the 9600GT is nowhere near the GTX 260 or HD 4870.
Btw if you read [H] reviews, you will know that they will play the games at the most GPU intensive part of the games. The FPS shown in the reviews are the worst case scenario in the games, you will probably get a higher FPS at a different part of the game.
as long as it isnt the 512mb 4870, both are fine.
Is the 512mb 4870 that bad?
Not really, it is just that the lower memory is really holding the card back. You won't notice it if you don't use a high resolution display but with high resolutions and a high amount of AA, the HD 4870 1GB will start pulling itself away from the 512MB.
Thanks for the reply... not trying to take away from the OP on the thread or something just a little worried. I was trying to build a cheap gaming rig for my nephew and put in the 4870 512mb card. I know he isn't going to be using some crazy display yet. And I thought it would be better choice for the price I got than a 9800GT.
Yes it does.
I bought the 4870 1GB, but I might exchange it for a GTX 260 216. Nvidia partners seem to have better perks (step-up, lifetime warranty, bundled Far Cry 2)...
