485W Enermax for 2900PRO
Likely not too well.I have that exact model,and have had nothing but problems with it.It was powering a....
X2 3800 @ 2.4Ghz
2x1Gb DDR PC3500
60Gb ata100
160Gb ata100
200Gb sata150
32x cdrom
16x dvd rom
7800GT 440/1100
2 120mm case fans
SB Live 5.1
5 port Firewire card
Until the reboots.Swapped it for a Corsair HX520.Of course your expirience may be different and more positive :)
X2 3800 @ 2.4Ghz
2x1Gb DDR PC3500
60Gb ata100
160Gb ata100
200Gb sata150
32x cdrom
16x dvd rom
7800GT 440/1100
2 120mm case fans
SB Live 5.1
Strange, you must have had a bum unit. My config is exactly the same almost. 3x HD, 2x optical, 7800gt, 4200+ and it has worked like a charm.
