4850 X2 or 4870?
Gonna try to see if my 550 can handle it, most things I am reading saying the power draw of the 4850x2 is less or equal to that of the 3870x2 so I dont think I will have an issue.
yeah, that should be fine depending on the brand. (i.e. cheap PSU gives problems regardless of wattage)
I would buy 2 4850 512mb to make it crossfire. It is abour $50 cheaper than the 4850 x2, and it is faster and cheaper than a single Nvidia 285. You can seperate the cards in the future for 2 PCs. It is just more flexible.
$50 Cheaper for half the memory ? I would have to chalk that up as "why bother"
Well the card is still going to a gray screen on me even after swapping the PSUs. It is impossible that it is anything else as the system is completely functional with the other card.
Do I RMA via Newegg or Sapphire? Newegg I am guaranteed a new card correct whereas with Sapphire I may get a refurb?
Sapphires warranty page seems to push you towards a retailer return first and foremost though I was going to create a ticket just in case.
Thoughts?
