4850 vs 4870 (more info in thread)
I'm going to wait for the 4870X2 to allow the 4850 and 4870 to drop in price a little then I have to decide either 2x 4850's now which I can xfire and power with my current PSU or 1 4870 then later this year a 2nd one but I need to upgrade my PSU not because it doesn't have enough power but I need more connectors. BTW Games I play
I'd like to finish Crysis at a reasonable framerate but I most likely will just fire it up to show people the prettiness.
1.Crysis warhead if the gameplay and storyline is good.
2.Farcry2 mebe
3.HL2 Ep3 and whatever they may release
4.TF2
5.SC2
6.Diablo 3
7. Supcom FA
I play at 1920x1200 resolution. Also my sig is oudated a bit I have a DFI X48 LT coming in tomorrow.
For those games even a single 4870 should do it. About the only games it can't handle maxed out at 1920x1200 are Crysis and Age Of Conan, and since you don't play AOC and Crysis Warhead will use a new heavily performance-optimised variant of the Crysis engine, you'll probably be able to max that out as well. In the future if you need more performance you can always add a second 4870, but right now there's nothing that would really need the extra performance from two 4850s over a single 4870.
I think it all depends about the resolution and settings. It's really not that hard to make any single card stumble in a lot of games if you crank up the settings at 1920x1200 or higher.
I agree 4850 O/Ced will handle everything but Crysis. You can get one for about 165 AMIR from newegg with a promo code. If you are going to W/C as well, I see no purpose to get the 4870. On Water people have been hitting 900+ on the core with a simple volt mod. GDDR5 does not have as much impact as we would have hoped for.
I would get the 4870, they are hitting the $269 mark at some stores. Its the same performance as a GTX280 and much much less money. Should allow you to play many games for a couple years to come. It probably wont be worth it to CF the 4870 when you eventually need more power, just step up to the newest card.
Actually, the 4870 is faster than the GTX260, but not always as fast as the GTX280. That said, it's priced far lower, and is a much better value.
