4850 VRM Question
Spaxspore
After looking at this card, where are the VRMs at is it the grey chips (which is what i was thinking) or is it the small black ones. I got heatsinks coming so i can put my 2xs1 on my xfired setup but i want to make sure i put them on the correct chips. I looked on thermal rights website but they have only pics for the 3850,3870 and the 4850 layout looks a tad bit different. Any help would greatly be a appreciated.
Thanks
Spax.
Vengance_01
You should* have a sink on each. Both the black and gray are covered by the stock cooler. What I did was use 1 for each or 6 in total. Under load they get super hot. Make sure you have some ram sinks. ;)
aldamon
I wouldn't worry about them. The stock heat sink looks like it insulates them. Like every other card I've owned for the last few years, all there is is crappy TIM and the same piece of metal touching the core/RAM "cooling" the VRMs. They obviously run fine hot.
lol_wut
With the stock heatsink, the heatsink metal is actually hotter than the components it's cooling. It actually heats them up instead of cooling them down.
However, I would still put heatsinks over the PWM area just to be safe. It never hurts to have extra cooling. You can make your own heatsinks if you have old parts lying around.
Spaxspore
Thanks for the pic that helps alot :)
Yea thats what i was thinking, but i got some on the way, better to have something on them then nothing.
